Core Support Mount Holes - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-19-2010, 04:00 PM Thread Starter
mighty454's Avatar
Hi,
I'm replacing my core support as the bottom radiator support panel was damaged in a wreck prior to me owning it. Half of the bottorm radiator support bracket got ripped off and not enabling me to install the bottom valance as it attaches to the radiator support to brace itself also to also.
My question is I have a replacement core support I found for my 1972 LeMans as they don't reproduce the core supports for the LeMans's anymore and only the GTO's.
The one I have is in great shape except for the holes where the rubber body mounts attach to the frame. The mount holes have lost their shape as they have rusted around that mounting area.
Does anyone know what size those holes should be? circumference= ?" inches
I'm going to have a local welder try to restore the mounting area. Thanks
mighty454 is offline
post #2 of 5 (permalink) Old 10-19-2010, 05:41 PM
Core supports I have seen are 7/16 bolts.Common fix is to weld a big flat washer over that area,grind welds smooth and paint the area....hope this helps.That is one sweet ride!!!!!!....JB.
1964 GTO Hardtop.
2009 R/T Classic
2008 Chevy LTZ
Retired and taking it easy!
Jerry64 is offline
post #3 of 5 (permalink) Old 10-19-2010, 07:42 PM
on both!
Eric Animal is offline
post #4 of 5 (permalink) Old 10-20-2010, 02:12 AM
67 Basket Case Restorer
Too Many Projects's Avatar
The hole is much larger than the bolt for the cushion to seat in. I would get a new set of core support cushions to see what size the hole needs to be.
OR, if the bracket that the cushion seats in is good on your old support, drill out the spot welds and transfer them to the replacement.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #5 of 5 (permalink) Old 10-20-2010, 04:07 PM Thread Starter
mighty454's Avatar
Thanks guyz for all of the suggestions. I'm going to start taking it apart and will apply your recommendations.
69 Radiator core support help!!!! 369GTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 10-10-2010 08:39 PM
72 gto radiator core support STOP rusting Goat! 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 04-12-2010 05:12 PM
65 radiator core support mounting trimfixer 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 03-10-2010 10:38 PM
1966 core support hardware 1966Dave 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 08-15-2009 08:56 PM
