Is this the correct seam sealer? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 04-02-2012, 10:10 PM Thread Starter
leeklm's Avatar
NAPA AUTO PARTS
Martin/Senour 4313 Click the napa link to take you directly to the page.
Need something for sealing my shift porch to the floor, as well as various items like sealing water plugs/plates to the floor etc. I would like something that stays thick like caulking.
Before spending $15 per tube experimenting, thought it would be wise to ask some of the experts here on the restore thread!
Thanks!
leeklm is offline
post #2 of 4 (permalink) Old 04-03-2012, 04:43 PM
Quoted: 23 Post(s)
I use Loctite PL Premium advanced polyester construction adhesive from HD on my trunk i just restored, Body guy told me it is exactly the same as the stuff they get 15 dollars for. It is like the seam sealer used on the trunk pan to inner wheel house joints and does harden. if you want flexible caulk use the OSI siding caulk (also HD), it will stay elastic forever and will not pull lose from a clean surface application, we use it for exterior siding, good stuff.....can you tell i built my car with a carpenters tool box?... I would use the adhesive on the flange before you screw it down and then seal the surface with the OSI, it will never shift or leak in (like that car will ever see rain again....)
Instg8ter is offline
post #3 of 4 (permalink) Old 04-05-2012, 11:07 PM Thread Starter
leeklm's Avatar
That stuff works great! I was going to purchase a welder, but think I will just buy a few more tubes of PL Premium instead... I will use the siding caulk and a few rivets for the shifter porch, since I may want to remove it some day without a torch!
leeklm is offline
post #4 of 4 (permalink) Old 04-06-2012, 08:03 PM
Quoted: 23 Post(s)
glad i could help...
72 Lemans Questions - seam sealer, dash pad Icefan71 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 7 08-27-2011 01:37 PM
Best/easy way to apply seam sealers the65gto 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 04-18-2011 10:17 PM
65 roof rail weatherstripping retainer sealer?? crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 08-02-2009 10:16 PM
gasket sealer marks64 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 07-24-2009 01:50 PM
Backseat Leather splitting apart at the seam NT91 Service, Maintenance and Technical Discussion 11 07-22-2008 12:56 PM
