Could use some help to identify this motor. - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-01-2017, 12:53 PM Thread Starter
Jason Metcalf's Avatar
Hello I am new to the forums and appreciate any help.
My father bought a 69 convertible GTO RA4 just before I was born and I have been helping him search for a matching engine (original is long gone) most of my life. I am in my 40s now and been kinda taking this on myself to keep looking. I recently found a 70 marked WW but the casting number is just throwing me for a loop. My father is asking his old Pontiac parts dealer if it makes any sense but he also suggested I reach out to a community for possible answers.
As far as I can tell it is the Tempest parts number from the catalogue
"Block assembly 479879" 1970/RAM AIR IV-CODED-XP-OR-WW
http://wildaboutcarsonline.com/membe...p_00_Parts.pdf
Is this possibly some kind of replacement block?
Thank you again,
Jason
ID:	87993   Click image for larger version
ID:	88001   Click image for larger version
Jason Metcalf is offline
post #2 of 3 (permalink) Old 03-01-2017, 02:04 PM
Not sure who has this for sale, but can easily state someone with questionable intentions had "some fun" with a grinder & set of stamps.
an original '70 WW or XP block would have a 979991(5) casting number. Both '70 RAIV GTO's & the 88 RAIV TransAms used these two codes, XP & WW. At the Pontiac engine plant, the last digit of a 9799914 400 block was ground off & a correct font 5 was stamped. A few original '70 WS blocks were also assembled on the 979991(5) casting block instead of normal use of 4 bolt main capped 9799914 casting block. Have owned several SR fitted "915" casting blocks, & have several friends that have documented SR fitted blocks in their cars, along with original dealership & zone paperwork
A SR 400 block cast for '70 model applications during the '70 model year would simply have a 979991(5) casting block with an SR8xxxx stamped near the timing cover area on the face of the block. Once the 481988 casting 400 blocks began being cast in late July of '70, all of the casting number was removed smoothly, & for a fitted 4 bolt main block, the entire 9799915 casting number was stamped with the correct font stamps. Whoever went to some trouble to fake the above block seems to not know hosnway around these SR blocks as far as how they were stamped. He also seems to have used some form of gangstamper on the assembly number & on their attempt to stamp the part number out of the Pontiac Master Parts books instead of correct application casting number.
SR 400 2 bolt main blocks for '67-69 usage & built as SR blocks during the '70 model year were stamped with the earlier casting number 9790071. More on the earlier SR 400 blocks:https://www.gtoforum.com/f83/1969-gto...tml#post760297
post #3 of 3 (permalink) Old 03-01-2017, 10:29 PM
Quoted: 78 Post(s)
Does that block have 4 bolt main caps?
Do you have a photo of the caps? Specifically the cap part numbers....
Shake-N-Bake is offline
Can you identify this pic? leeklm 1964-1974 Tempest, Lemans & GTO General Discussion 8 03-29-2012 06:35 PM
Please help identify this sensor Pontiac_Madness 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 12 01-30-2012 07:37 PM
Help identify this part!!! DaleGolds 1964-1974 Tempest, Lemans & GTO General Discussion 3 05-05-2011 08:44 AM
can anyone identify these wheels? busaben 1964-1974 Tempest, Lemans & GTO Wheels & Tires 7 03-07-2011 07:16 AM
Can You Identify This Car? GTO JUDGE The Lounge 17 06-18-2008 08:09 AM
