Crankshaft Question - Pontiac GTO Forum
post #1 of 2 (permalink) Old 01-17-2014, 08:53 PM Thread Starter
Crankshaft Question
Hey Guys:
My RA III engine is in the shop and I'm faced with the question of regrinding the crank that was in it to 20/20 or going with a later model spare I have which is already ground to M20/R10. the regrind cost is $250. The hub sizes on the rear of the crank are the same. They both, by casting number, are nodular. I ended up into the motor for boring, line boring, valve guides, pistons, rings, bearings, cam, lifters, valve job, timing gears, oil pump & shaft, probably resizing the rods plus small stuff. I guess the $250 isn't too much to spend if there is any real advantage to keeping the original crank with it. What do you think?
Chemnick
chemnick is offline
post #2 of 2 (permalink) Old 01-18-2014, 11:25 AM
Quoted: 118 Post(s)
Up to you. No 'real' difference. Me, I would reuse the original crank, because I'm just that way. 'Born with' parts always seem to work a bit better for me. That said, these cranks are very beefy and can be cut .040" under with no issues to be concerned about.
Need crankshaft for my '66 Miami Ragtop 1964-1974 Tempest, Lemans & GTO General Discussion 2 11-19-2012 10:50 AM
Crankshaft pulley is wobbly 1974GTO 1964-1974 Tempest, Lemans & GTO General Discussion 5 04-04-2012 01:52 PM
new to gto crankshaft position sensor gona440 Service, Maintenance and Technical Discussion 4 06-08-2011 06:45 PM
Camshaft ID, Crankshaft ID Help needed. Lukeduk1980 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 06-01-2010 10:00 PM
