Dan's 69 Restore Tale - Page 76 - Pontiac GTO Forum
dan woodland, Nightshade 68 HO
 74Likes
post #751 of 759 (permalink) Old 05-31-2019, 02:42 PM
Stereolab42's Avatar
Originally Posted by dan woodland View Post
Unfreaking believe-able!!!!
Attachment 119333
4 inches in last few days...............
We got rained out for most of May here in Cali also... but luckily it's over. 80s as far as I can see and I took my 68 to work today!
Stereolab42 is offline
post #752 of 759 (permalink) Old 05-31-2019, 04:23 PM Thread Starter
dan woodland's Avatar
Quoted: 34 Post(s)
Your lips to Mother Nature's ears!!!
They are calling for rain every day but two in the next 10... simply amazing.
*67K miles... Under Construction* :)
dan woodland is online now
post #753 of 759 (permalink) Old 06-08-2019, 10:38 PM Thread Starter
Quoted: 34 Post(s)
21.5 inches of rain... finally 3 consecutive days without rain.................... wait for it............................ the other shoe has dropped... my street will be torn up for the next two months starting on the 13th! If normal practices hold true for our street as others in our neighborhood I won't be able to get in or out my drive for 3 or 4 weeks at some point , we'll have to park on other neighborhood streets - they are doing drainage, curbs and sewers... summer drive time just got cut drastically - bummer.
post #754 of 759 (permalink) Old 06-18-2019, 12:48 PM Thread Starter
Quoted: 34 Post(s)
List shrinking list is growing again!!!!
1. Vacuum canister loose - turns out it's the canister on the mount not the mount on the fender. Subsequently the mounting bolt holes are nearly stripped (probably happened when body mounts were done)... battery has to be removed first...
2. Mount driver side courtesy light
3. Install seal on A/C vent at heater box - OE was some really sticky stuff I forgot to get - got from a member here.
4. Install OE heater control knobs.
5. Install OE AM/FM radio/new front speaker
6. install OE missing upper Fender bolt
7. Install OE bucket seat nuts/bolts - passenger side - pulling this to reinstall A/C vents etc.
8. Reinstall center console and A/C vents - removed for dash/radio fixes...
9. Driver side fender rattle (damned streets are shaking her apart).
10. Rebuild carb again with better rebuild kit. She bogs down when hot as I hit the throttle - 90 percent sure it's the accelerator pump seal. Need to get info from Bear again.
post #755 of 759 (permalink) Old 06-25-2019, 03:15 PM Thread Starter
Quoted: 34 Post(s)
Sun = Drive time... been sunny so I've been layin rubber all over town. Only issue, cops are EVERYWHERE!! Can't open her up much... must be some kind of crackdown or budget time...
Had an Airborne bombing the other day... Tech Shine (applied wet) wax did great. light spray of water or detailing spray and a light wipe clears it up. That Tech Shine is great stuff.
Crazy how shinny it is... Didn't realize how until I saw the reflection in the pics.
soberjoe likes this.
post #756 of 759 (permalink) Old 06-27-2019, 04:58 PM Thread Starter
Quoted: 34 Post(s)
Ah, love that smell....
Got that out of my system...
Started to work on her again.
when the interior was installed they missed a broken rear seat frame on the passenger side... I took her in the other day and they fixed it (welded) and fixed the bent seat frame. There was over 1.5 inches of space between the cushions.
Also patched an irritating hole in the exhaust - it was just enough to make a puffing sound. Used a bit of JB Weld, great stuff.
Some day I'll be done, I don' really believe that...
post #757 of 759 (permalink) Old Today, 08:25 AM Thread Starter
Quoted: 34 Post(s)
Finally got to work on some things... been driving her every time I get the chance. So far this year has been thunderstorms or sun. It's been crazy, July 5th my neighborhood was under water. Luckily we bought on top of the hill not the bottom. three quarters of the neighborhood was under water including some classic cars. Sad.
Headlights have always worked slowly and the vacuum canister had begun to rattle on the fender so I decided to look into it. I found the canister had come loose from the bracket as it was only "pressed" in by some small metal tabs. I figured the tabs would come lose again at some point and I'm not a fan of doing things over and over so I tacked the bracket on the canister and performed a smoke test. The nipple connection is leaking badly and I have another leak on the seem. I'll have to clean it up, address the leaks then repaint.
post #758 of 759 (permalink) Old Today, 12:04 PM
1968gto421's Avatar
Quoted: 70 Post(s)
Good goin' Dan. It's a lot of trouble, but the FUN is worth it!
1968gto421 is online now
post #759 of 759 (permalink) Old Today, 01:21 PM Thread Starter
Quoted: 34 Post(s)
Agreed, now I just need to figure out how to make my car stealthy so I can avoid the plethora of po-po out to get me. It's been pretty hard to open her up so far this season.
Currently Active Users Viewing This Thread: 21 (0 members and 21 guests)
Hello From [email protected] in CT [email protected] Member Introductions 0 10-01-2009 10:53 AM
Need Some '65 Restore Help dwitzel 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 07-23-2009 08:50 PM
Chasing the M3: A Cautionary Alignment Tale Groucho Drive train, suspension, alignment and brakes. 9 05-07-2006 02:35 PM
Dan Gurney Loves His! Duck916 2004-2006 GTO General Discussion 2 09-12-2005 08:13 PM
I agree with Dan Gurney Punchy 2004-2006 GTO General Discussion 0 09-02-2005 06:40 AM
