difference between 1970 GTO and 1971 Lemans - Pontiac GTO Forum
post #1 of 6 (permalink) Old 01-08-2014, 10:51 AM Thread Starter
I have a 1970 GTO that I am trying to restore. The car is in decent shape for the year but am trying to save some money restoring it by using panels, doors and what not off a 1971 Lemans. I was wondering what are the differences between the two cars. I do not own the Lemans yet, which is why I am asking if they are enough alike??? What are the differences? I would appriciate all and any help. Thanks
kickn59 is offline
post #2 of 6 (permalink) Old 01-08-2014, 05:29 PM
Quoted: 23 Post(s)
whole front clip with hood are different but should fit if complete change over. Believe the doors and quarters are the same. Your GTO will lose value with the lemans parts, best to find 70' parts for the GTO.
Instg8ter is offline
post #3 of 6 (permalink) Old 01-08-2014, 06:01 PM
Red1970GTO's Avatar
Goat Resto
Yes, the front clip is obviously different, however other than the front clip, the only piece that is not identical (not counting emblem holes) is the rear seat/trunk divider. The doors, quarters, trunk lid, roof, skeleton, etc. are all the same basic parts -- they all came from the same presses. Weld up the emblem holes and refinish the holes on the inside and all will be well.
Red1970GTO is offline
post #4 of 6 (permalink) Old 01-09-2014, 05:42 PM Thread Starter
Thanks for the help!!
kickn59 is offline
post #5 of 6 (permalink) Old 12-17-2014, 09:14 AM
what about the core support? I have a 71 lemans with a 70 gto fiberglass 1 piece cap on it and I'm trying to go back all steel 70 gto parts. What should be changed?
junction44 is offline
post #6 of 6 (permalink) Old 12-24-2014, 08:01 AM
If you're using the metal from the 71 and welding onto the 70, that is those that fit, you have a car that should theoretically be worth more than a car patched up with Asian import panels. Document your restoration and yes, get REAL GM sheet metal whenever you can. If you take the car as a whole, use the LeMans shell, maybe not so much since the market can't pay attention long enough to understand the concept of RESTORE vs COPY. I could bore this place to tears on the topic but I won't.
666bbl is offline
1970 1971 1972 lemans electronic repair manual needed brett.f.thompson 1964-1974 Tempest, Lemans & GTO General Discussion 0 04-28-2012 01:03 PM
1970-1971 GTO interior color options.. 70Judge 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 01-04-2010 08:56 AM
Pontiac GTO 1971 or 1970 kustodian 1964-1974 Tempest, Lemans & GTO General Discussion 12 10-14-2009 12:07 AM
