Disc brakes - '72 El Camino - Pontiac GTO Forum
post #1 of 3 (permalink) Old 03-19-2011, 01:26 PM Thread Starter
Any idea if the disc brake setup from a '72 El Camino work on a '66 GTO?
Thanks!
Chris
Denver, CO
thegangler is offline
post #2 of 3 (permalink) Old 03-19-2011, 03:08 PM
Quoted: 23 Post(s)
should work, i have 70 GM single piston on mine only mod was drilling one bolt hole in the spindle out a bit.
explains swaps here
Guide To A-Body Disc Brake Swaps- Car Craft Magazine
Instg8ter is offline
post #3 of 3 (permalink) Old 03-19-2011, 03:46 PM
FNG69's Avatar
Brian covered this good already!! This the same year of A-body I pulled and put on my 64. Pretty easy change over too. Good Luck, Les
FNG69 is offline
Converting Drum brakes to disc Welby 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 06-25-2010 10:21 PM
Converting Drum Brakes to Disc on 65 MikeMcGinn 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 22 04-21-2009 09:18 PM
69 Pontiac GTO Rear Disc Brakes josemusclecar 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 9 11-29-2007 05:32 PM
To Convert to Disc Brakes or Not red68gto-Joe 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 10 06-01-2006 11:54 AM
Disc Brakes gman26 Drive train, suspension, alignment and brakes. 7 10-28-2005 04:31 PM
