DIY on a budget... - Pontiac GTO Forum
post #1 of 19 (permalink) Old 02-10-2012, 09:21 PM Thread Starter
Quoted: 23 Post(s)
DIY on a budget...
Thought i would start a thread with some tips for restoring on a budget as we all know how quickly these cars of ours can drain a bank account. Truth of the matter is if you have a pile of cash and order everything you need so you have it when you need it you will have spent more than its worth in this economy (even doing it all yourself).
I am not leaning towards correctness as much as presentable "on a budget". The way i look at it the goal is to get the car on the road running good and looking clean, then while driving and enjoying it you can get all the new little goodies in time with less of a strain on your budget and marriage. And what can be More Correct than saving as many original "Born With" parts as you can. The Purist will probably scoff at this but not all of us have a spare 30K or more laying around to build a 100 point car. My goal all along with this build was not a clone a GTO but build a car that embodied the Pontiac Spirit and i do have every factory trim part that the car cam with restored and stored also.
First tip: I highlighted the Ames book and gave it to the wife and daughters so they can pick a piece i want in their budget and get me usable gifts for x-mas and b-day
Ok have been wanting a wood wheel since i started the resto, scoured e-bay and Craigslist, but i am sorry, i am not paying $400.00 for a wood look wheel and even shy away from the real wood Aftermarkets (on above list but the wife would not pay $200...lol) so here is what i did...
factory fresh...
First job is to clean it up, simple green works well, then attack the chrome with 0000 steel wool get all the loose paint from the textured recess of the horn bar...with the horn bar off i masked and sprayed the column as i was painting the wheel and metal dash to match the exterior of the car (i know, not always correct but it looks good).
also cleaned up the dash with the wheel off and painted the bezels with a brush, since i was doing the wood insert did not need to be perfect on the outer edges. the horn buttun was removed and mouted on a flat surfaces so i could wet sand the scratches out of the acrylic and polish it. I also masked and sprayed the horn bar 60% black in the reliefs, install the wood insert before you put the wheel back on...it's much easier to trim and fit
My wheel had cracks in the usual places and thought about refinishing but that was a lot of work to get a wheel that felt hard and awkward in my big hands so i decided it would get covered in leather...the vinyl was just while restoring as it made it easier to crank the wheel when pushing it around. I found a place on E-bay that had leather wraps with a thin foam backer in all diameters and ordered for 20.00 i think. you want it on the small side so you have to stretch it tight over. The first thing you do when you open the package is throw away the dull needle and thread as all you can do is hurt yourself with it. My solution, when the leather is on and trimmed nicely with an x-acto around yoru horn bar make sure the seam where ther is overlap is facing the front of the car (back of the wheel) take a hotglue gun with permanant glue an work a thin bead around the inner layer, then whipe the leather where it will overlap only with acetone to get the oils off and lap over tight and seal the edge of nice and clean....no stitching needed and it will not move a bit on the wheel even if you twist it.
so for a little bit of elbow grease a can or two of spray paint the Standard Wheel can look good and feel better in hand for 20 bucks...thats $380.00 more you can put in yoru engine....
Feel free to add tips guys....i am just killing some down time and thought i would throw this out there....
Instg8ter is offline
post #2 of 19 (permalink) Old 02-12-2012, 11:13 PM
FlambeauHO's Avatar
Quoted: 8 Post(s)
Looks great! Cleaned up really nice!
FlambeauHO is offline
post #3 of 19 (permalink) Old 02-13-2012, 07:50 AM
Great idea for a thread! I'll see if I can't dredge up some stuff to contribute.
post #4 of 19 (permalink) Old 02-15-2012, 07:52 PM
Brian, Cool thread....how about including your "custom dashpad repair"..!! eric
Eric Animal is offline
post #5 of 19 (permalink) Old 02-16-2012, 12:27 PM
Quoted: 103 Post(s)
Great idea for a thread, I agree. I'm all for fixing what needs fixed and repairing as you go. Keeping the car operational the whole time, if you can. Now, if only I had some ideas! One thing I'll say is that I've always had better luck refurbishing original parts than I have had with repop parts. It's worth the time, it saves money, and the parts fit and work as they should. I think the only repop parts I have on my two goats is some trunk weatherstrip and a couple of fuel filter brackets. When doing the '67-up cars, I like to fit '66 style window cranks. My convertible has '66 cranks and a '66 rear view mirror inside....they're all metal and don't fall apart like the '67-up pieces. I also think they look better, even though they're not "correct". I'd also rather run a repaired original steering wheel than an aftermarket wheel....
post #6 of 19 (permalink) Old 02-16-2012, 12:41 PM Thread Starter
Quoted: 23 Post(s)
Thanks guys, plan on keeping this going if there is interest....will have a breakdown on the dash E, i am currently working on a members and making molds so they will be available if others like the gauges, am taking pics and will add it as soon as i get done. GeeTee i like the crank swap...the all metal look so much better than the yellowed plastic.
Heres a little one i ran into....72' motor in a 66' car, the 72' is equipped with the 18" clutch fan (best for cooling the beast) well, the fan shrouds for the 66' are made for a smaller fan....so rather than trying to find a fan to match the shroud i trimmed a equal amount off the tip of each fan blade with a set of scissor shears it fits the shroud with less than 1/4" clearance and draws air like a vacuum.....
post #7 of 19 (permalink) Old 02-16-2012, 01:06 PM
My original steering wheel had big problems... the Texas Heat had caused it to start decomposing, giving off all manner of weird gasses/vapors that would coat the insides of the glass and everything else, in addition to making the surface of the wheel gummy and sticky. I surprised when I wasn't able to find a replacement, and I balked at paying the price for a 'correct' wood wheel, so I'm running an aftermarket wheel that looks "reasonable" and even has the Pontiac Arrowhead horn button, but it ain't "correct'.
post #8 of 19 (permalink) Old 02-16-2012, 04:27 PM
Quoted: 103 Post(s)
Bear, you're dealing with different materials than I am with the older cars. You pretty much have no choice. You have to run with what works....and leaves your hands non-sticky. Inst, GTO's came with an 18 inch fan stock, and AC cars had a 19.5 inch fan. I have shrouds on both of mine....an 18" fan on the '67, and a 19.5" fan on the '65...I had to get an AC shroud and adapt it to fit my non-AC car. No biggie. Perhaps Tempest/Lemans fans were smaller in diameter.
post #9 of 19 (permalink) Old 02-16-2012, 04:56 PM Thread Starter
Quoted: 23 Post(s)
just measured GeeTee, your right of course...19" shroud, so my fan must have been off a 72' AC car and been 19.5 or 20, i guess this is the whole point of the Thread, making what you have work for you. I had to take around a quarter inch off each blade, i guess thats why they call it building a car and not just putting one together...
post #10 of 19 (permalink) Old 02-16-2012, 05:01 PM
Can you post some better pics of your steering wheel Instigator? Nice looking job on the dash and I like the way the black and blue contrast together with the carpet and dash.
Budget head and cam. MadGoat04 Engine Discussions 12 09-05-2010 02:28 PM
Headers on a budget. barbedwire88 Intake and Exhaust Discussions 30 11-21-2009 06:24 AM
Mods for a newbie with a budget? jmjacks Engine Discussions 10 04-05-2009 03:17 PM
on a budget ? bs motorsports Engine Discussions 2 08-28-2008 07:44 AM
Budget... Joey R Wheels and tires 10 04-08-2007 12:34 AM
