Door alignment issue - Pontiac GTO Forum
post #1 of 5 (permalink) Old 03-19-2019, 07:27 PM Thread Starter
Quoted: 4 Post(s)
Guys, I'm having trouble adjusting my passenger door. I have a new door shell, A pillar and new hinges and when I tighten the lower door hinge to either the door or the body, it pulls the door down on the back. I can adjust it and when I open the door it drops about 2 inches. The drivers side went perfectly and I cant figure out why it's doing this. Any help would be greatly appreciated
David18 is offline
post #2 of 5 (permalink) Old 03-19-2019, 07:34 PM
Quoted: 33 Post(s)
Have you tried loosening the top body hinge bolts some and pull up on the door? They both have to move the same.
tjs72goat is offline
post #3 of 5 (permalink) Old 03-19-2019, 07:58 PM Thread Starter
Quoted: 4 Post(s)
Yes, I've had the top bolts loose, it doesn't seem to matter which ones I tighten first the bottom bolts always pull the door down
David18 is offline
post #4 of 5 (permalink) Old 03-19-2019, 10:16 PM
BLK69JUDGE's Avatar
Quoted: 57 Post(s)
wrong hinge ?
what year and model ?
BLK69JUDGE is online now
post #5 of 5 (permalink) Old 03-19-2019, 11:48 PM Thread Starter
Quoted: 4 Post(s)
67 gto hard top. The hinge looks correct. After staring at it for a ridiculous amount if time i think it may be the repop door shell. If I loosen the bolts holding the hinge to the door and align the door there is about 3/16" gap between the bottom of the hinge and door. This makes me think I got a bad door. The only other thing that could cause this is if the A pillar is installed wrong but the angle of the a pillar is correct.
David18 is offline
06 Rear alignment issue 1SLOWGTO Drive train, suspension, alignment and brakes. 8 01-26-2011 07:49 PM
1964 Convertible Door Alignment Wedges? Al T 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 6 09-16-2010 10:26 AM
Alignment issue, or front strut issues? tiger gto 2004-2006 GTO General Discussion 9 03-14-2007 02:19 PM
Alignment issue Taxman Drive train, suspension, alignment and brakes. 21 11-28-2006 02:18 PM
Door Alignment Toebee Service, Maintenance and Technical Discussion 2 06-20-2005 11:08 AM
