droopy rear view mirror and visors....1968 - Pontiac GTO Forum
post #1 of 6 (permalink) Old 11-13-2015, 09:57 PM Thread Starter
can someone tell me what I need to buy to take care of both of these!
The mirror is annoying and worse than the visors.
Also, is it possible to remove the mirror and have a glass shop or someone replace the mirror? After almost 50 years it has developed a funk (for lack of a better term) in the glass.
Thank you!
Jgoose514 is offline
post #2 of 6 (permalink) Old 11-17-2015, 04:58 AM
That funk you see in your mirror is the the glue that's supposed to be holding the mirror in the housing. If I'm not mistaken, it's where the reflective backing on the glass is pulled apart so now you can see through the glass in those spots. You should be able to find a shop that can replace it with an online search. As far as everything not holding, your friction surfaces are worn out. You might be lucky by crimping the visors where the mount pin goes into the visor. I had this work on my C10 pickup. Not sure on the mirror. Maybe a piece of electrical tape put into the socket of the ball mount would last a while?
MacsGTO is offline
post #3 of 6 (permalink) Old 11-18-2015, 01:03 AM
Quoted: 106 Post(s)
A drop of crazy glue on the ball in the back of the mirror and hold it in place for a minute should hold it.
I think Ames has reproduction mirrors, if not OPGI carries them.
Same thing with the visor mounts.
Goat Roper is offline
post #4 of 6 (permalink) Old 11-18-2015, 12:53 PM
AlaGreyGoat's Avatar
Work a little silicon sealer into the ball and socket area of the mirror and let it set.
You can force the mirror to move, afterwards. If you use crazy glue,
you may not be able to readjust it.
Larry
AlaGreyGoat is online now
post #5 of 6 (permalink) Old 11-20-2015, 06:27 PM
how do you guys get the visors to keep from dropping down all the time, this is annoying me badly
Porsche 2015 Macan Turbo (white)
Porsche 2012 997.2 Twin Turbo (white)
Porsche 1996 993 Twin Turbo (guards red)
Dodge 1970 Challenger (B5 Blue)
Porsche 1968 911 (?--in shop being repainted, haven't chose color yet)
Pontiac 1966 GTO (blue)
ChristianR is offline
post #6 of 6 (permalink) Old 11-20-2015, 07:22 PM
Quoted: 106 Post(s)
New grommets and there should be a screw to tighten the shafts.
Ames carries repro parts if that doesn't work.
Get a catalog here.
Ames Performance Engineering, Classic GTO Parts, Firebird Parts, and Full Size Pontiac restoration parts.
rear view mirror beer guy 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 04-28-2016 10:55 AM
Hard to see rear of goat through inside rear view mirror common right?.... pctek 2004-2006 GTO General Discussion 8 11-22-2010 07:59 PM
Remove Rear View Mirror chuckD Interior Discussions 0 06-11-2009 11:01 AM
Rear view mirror JToms 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 1 11-16-2008 06:54 PM
Auto Dimming Rear View Mirror SJAndrew Interior Discussions 12 06-29-2006 03:30 PM
