Engine ID numbers - Pontiac GTO Forum
post #1 of 3 (permalink) Old 10-15-2018, 05:54 AM Thread Starter
Engine ID numbers
Recently purchased a used GTO and trying to determine what engine is installed..
stamp code, front of block is: YC 346883
But below the ID is 4659 which has been stamped over with hypens and below it is stamp 4685,,as a corrected #..??
DDEESE is offline
post #2 of 3 (permalink) Old 10-15-2018, 10:03 AM
Quoted: 73 Post(s)
A YC code engine could be a 350, 389, 400 or 455, depending on what year it was used.
Wallace Racing's Pontiac Engine Search
You need to get the block casting number & date code from the rear of the block.
https://www.hagerty.com/articles-vid...-engine-blocks
http://www.teufert.net/identify/identify.htm
http://www.pontiacpower.net/numbers/
https://www.pattersoncoachworks.com/pontenginecodes/
bigD is online now
post #3 of 3 (permalink) Old 10-15-2018, 04:52 PM
Yes - always begin with the 4 character date code, cast into the top of the block near the distributor. You must start with this because Pontiac reused the same two character stamping (passenger side front) in different years to mean different things. The date code is one alpha character denoting month (A=January), followed by day, with a 1 digit year at the end. The engine foundry would "swap over" and begin casting blocks for the next model year in about mid year, so a date code of say F278 (June 27, 68) would probably be a model year 1969 engine. Next get the block casting number - located in different places in different years. The web sites that BigD posted above can help you know where to look. This tells you if it's a 389, 400, 421 etc... Last thing to look at is the two character stamping on the passenger side front near the top of the deck. (YC in your case). This tells you details of how it was built (which cam, carburetor, etc) and also which type of car it was installed in and what kind of transmission was behind it.
69 GTO 400 Div Choke Assy Info Neded - Need to ID GM Parts Numbers Lfryklu 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 10-04-2015 11:55 PM
Camshaft ID, Crankshaft ID Help needed. Lukeduk1980 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 3 06-01-2010 11:00 PM
Engine ID phatboy2180 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 2 05-13-2009 09:41 PM
Engine ID questions 66GTO7.5L 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 15 04-21-2009 12:38 AM
Finally got engine ID macgto7004 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 9 04-16-2008 02:01 AM
