Factory paint: did the dash color match the exterior color? - Pontiac GTO Forum
 2Likes
post #1 of 17 (permalink) Old 07-02-2018, 12:06 AM Thread Starter
torpedo51's Avatar
I'm restoring a 65 GTO to the specs used when it rolled off the assembly line (have PHS docs).
I'm painting it with a factory scheme and factory colors (correct semi-gloss black on pan, factory color chip for exterior, factory spatter paint in trunk, etc.)
The paint shop is trying to convince me that the dash should be a different color than the exterior - that it should match the interior color (upholstery/door panels). I suspect they are confusing some other GM car, like a Chevelle with my Pontiac project.
Do you any of you have a restoration guide, and could you tell me whether the dash is supposed to be a color other than the color of the exterior?
FWIW - the exterior is Blue Charcoal Poly and the interior upholstery will be Black.
Tim
torpedo51 is offline
post #2 of 17 (permalink) Old 07-02-2018, 12:17 AM
Quoted: 79 Post(s)
Can you post a photo of your body trim tag? Need your trim code...
Shake-N-Bake is offline
post #3 of 17 (permalink) Old 07-02-2018, 02:23 PM Thread Starter
torpedo51's Avatar
The trim tag was stolen by the prior body shop.
I do have the PHS docs. What code am I looking for?
post #4 of 17 (permalink) Old 07-02-2018, 04:32 PM
Bob Young's Avatar
213-30 would be black semi gloss and flat. The instrument surround would be flat rough, lower dash Black semi gloss and the top of the dash from the pad to glass should be flat.
Would help to know what code you are working with to be sure.
Bob Young is offline
post #5 of 17 (permalink) Old 07-02-2018, 04:42 PM
Quoted: 79 Post(s)
Page 3 of the dealer order form from your PHS docs should have an example of the trim tag and a legend at the top of the page. Your codes would be highlighted in yellow. Blue Charcoal exterior code is "B". On the right side is a legend for interior trim color codes. What is highlighted there?
Should also be on the BHC. Look for a box with color or trim...
post #6 of 17 (permalink) Old 07-02-2018, 04:50 PM Thread Starter
torpedo51's Avatar
Ok, got it.
This car originally came in Teal Turquoise (L) with a Turquoise interior (214-36).
I'm painting the car Blue Charcoal (B). Which interior color was typically matched to this?
Choices: Black, Turquoise, Gold, Red, Blue, Parchment & Black.
I'm guessing it wasn't Blue, because that would be weird. We can rule out Gold, Red and Turquoise. So either Black or Parchment.
Both of those selections mean that The dashboard and inner door sills were black?!
Does anyone have photos of a Blue Charcoal car? I'm looking at the Ultimate GTO site, and can't tell if the interiors are Blue or Blue Charcoal.
T
post #7 of 17 (permalink) Old 07-02-2018, 05:44 PM
Quoted: 389 Post(s)
Ok, got it.
T
Factory interior color choices with the Blue Charcoal paint were black, dark blue, or parchment. Optional exterior pinstripe color was ivory.
post #8 of 17 (permalink) Old 07-02-2018, 06:17 PM
Quoted: 79 Post(s)
Looks like B exterior color was available with 213-30 Black, 217-33 Blue or 218-3E Parchment interiors. If I am reading the charts correctly. ..the dash would be black for the black or parchment interiors and dark blue for the blue interiors.
There is a color code for Blue Charcoal interior dash paint but it doesn't appear that was used on any of the 237 (Le Mans) models. Maybe only on the Tempest line?
integrity6987 likes this.
post #9 of 17 (permalink) Old 07-03-2018, 03:20 PM
Quoted: 16 Post(s)
What book is that? Does it have the codes for 1964.
tonyskala is offline
post #10 of 17 (permalink) Old 07-03-2018, 03:35 PM
Quoted: 79 Post(s)
From some book that I picked up years ago... don't remember where though?
Here are the 64 colors.
Help to match Nocturnal Blue paint Dirtcop1947* 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 2 02-14-2018 08:16 PM
Paint to match (clean up) interior parts leeps 1964-1974 Tempest, Lemans & GTO General Discussion 0 02-23-2017 11:48 PM
2004 GTO Factory Match Interior Paint Search Badkat Interior Discussions 0 04-19-2016 06:55 PM
Paint code search does not match PPG 14718 my67goat Member Introductions 1 04-26-2015 10:58 AM
Need Verdoro paint match jbs 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 8 08-08-2012 01:20 PM
