Fender Alignment Problem 1968 GTO - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-05-2014, 09:43 PM Thread Starter
Hey Everyone,
I currently have a 1968 gto I am starting to restore. Now this is my first restoration and I am learning alot as I go. I also picked up a 1968 Tempest that is pretty complete for a parts car.
I was planning on using the parts car fender because it was very straight other than a needed patch panel behind the tire. My original fender also needed patch in same spot but also had a crease near the valance.
The issue I am having is that the top of the fender door has a pretty large gap. It is already brushing the door when opening and closing. If I move it in anymore the door will no longer open. I have already moved the door back as much as I can and alighted it pretty good.
What else can i do or check on why there is a large gap at top.
I am going to attach a picture and circle the area
Name:	gto door issue.jpg
young99 is offline
post #2 of 3 (permalink) Old 12-06-2014, 01:03 AM
68-GTO's Avatar
Ive the same issue,
ive clear it when i take the rubber bushings between core support and frame out.
ive only a few shims now in place.
when the whole frontend comes a little bit higher the gap from fender to door are smaller.
68-GTO is offline
post #3 of 3 (permalink) Old 12-06-2014, 12:13 PM Thread Starter
Thank you for the update I will check this out. I have a new core support hopefully coming in soon been on back-order for 1 month . I already have new bushings ready to put on.
I probably should start a thread on this restoration. I will end up having more questions im sure.
Thanks again.
young99 is offline
1968 Inner Fender Replacement young99 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 1 07-03-2014 05:02 PM
1968 GTO Fender question joedee 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 06-07-2013 02:09 PM
1968 GTO Front Rotor Problem 1625Goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 06-26-2011 09:58 PM
alignment problem 6.0goat Service, Maintenance and Technical Discussion 1 09-29-2007 06:27 AM
1968 GTO Fender Rub GTOBOB 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 2 09-10-2006 07:06 PM
