Fender emblem removal - Pontiac GTO Forum
post #1 of 7 (permalink) Old 12-26-2013, 11:30 AM Thread Starter
Dozermatt's Avatar
How does a guy remove the fender emblems off a 1966 gto?
Dozermatt is offline
post #2 of 7 (permalink) Old 12-26-2013, 02:34 PM
FNG69's Avatar
Two studs on back with 3/8 nuts on them. Easy way is with the fender off!!!!!!!!!!!!!!!
Uploaded with ImageShack.us
FNG69 is offline
post #3 of 7 (permalink) Old 12-26-2013, 03:25 PM Thread Starter
Dozermatt's Avatar
Is there a way yo do it with the fender on?
post #4 of 7 (permalink) Old 12-28-2013, 06:53 AM Thread Starter
Dozermatt's Avatar
Took the fenders off. One fender was a replacement and had the 3/8 stamped nuts on the studs, the other -which was original as far as we know, had compression clips in the holes, the emblem studs were just pushed through them. So which is original and correct?
post #5 of 7 (permalink) Old 12-28-2013, 10:01 AM
FNG69's Avatar
The 3/8 steel pal nuts are original. If you buy new emblems you will get two new ones with it.
FNG69 is offline
post #6 of 7 (permalink) Old 12-28-2013, 10:07 AM
jmt455's Avatar
Do the press-in clips look like these?:
https://secure.amesperf.com/qilan/De...A&web_access=Y
These pressed-in "barrel" clips are aftermarket replacements.
You can get 4 of them for $2.00 from Ames Performance.Ames Performance Engineering, Classic GTO Parts, Firebird Parts, and Full Size Pontiac restoration parts.
It's not very noticeable, but the barrel clips don't allow the emblem to fit tightly to the fender; the emblem will sit slightly "proud" of the fender surface (about 0.030").
I have used both clip styles on various cars over the years. You can't beat the convenience of the barrel clips, but I prefer the OEM style nuts because I can get the emblems snug against the fender and therefore less likelihood of snagging car wash rags and polishing cloths on the emblems.
1968 Pontiac GTO
2008 Pontiac G8 base
jmt455 is offline
post #7 of 7 (permalink) Old 12-30-2013, 10:26 PM Thread Starter
Dozermatt's Avatar
Yes they were barrel clips, as we were taking the fender off it became apparent that it was a replacement. I can see that the barrel nuts are very handy though and these were fit fairly tight, I didnt notice any difference from the nuts on the other fender but im sure there are many instances where this is not the case.
64 Tempest Emblem Removal 64phil 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 07-15-2013 01:39 AM
64 GTO Front Fender emblem location pbearly 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 3 05-07-2013 09:00 AM
Fender removal help CFC 2004-2006 GTO General Discussion 3 11-16-2010 02:48 PM
fender and quarter emblem templates needed torpedo51 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 8 09-27-2010 02:25 PM
