Finally, really getting started on the Lemans - Pontiac GTO Forum
post #1 of 75 (permalink) Old 10-10-2011, 06:27 PM Thread Starter
Well, I got sick and tired of being sick and tired and waiting to get the car in the garage, so Friday night when I got home at 12:30am from work, I decided I needed to just get out there and do something. Ended up removing the hood and pass. fender, and all but one bolt on the driver's side. Was trying to be quiet.
Saturday went out and did some more. Got the other fender and both wheelwells off. Removed the back seat. Strange thing was it wasn't even attached AT ALL. Just sort of lying there. Removed the engine compartment wiring harness, only had to cut a couple of wires. Since I am not reusing it, I wasn't too worried.
Oh, I also got the doors off. Was wanting to either build something or at least use the engine hoist, but decided heck with that and just did it. Not as easy as it used to be, but didn't kill me either.
Sunday I figured I have to get it into the garage now. So I greased the caster bearings on the dollies as much as I could, and surprisingly the car rolled easily. As long as I didn't want to change directions that is. So I had to position the casters for each direction change. But the car is in the garage.
So I piddled around a little more. Got the front seat and all seat belts and all carpet out. Only a little surprise waiting. Guess it could have been worse. Not sure if I have a picture here at work of it or not, found a couple of orange colored sheet metal pieces attached to the passenger side floorboard/toe area. Maybe a foot by a foot or less.
Oh, speaking of surprises, I found out that the trunk floor had been fiberglassed on the outer portions. So I will definitely be replacing the trunk floor. Not sure yet if the smaller one piece will be enough, or if I will have to replace the whole thing. Also in the trunk, I was looking at the hinges seeing what to remove since I will be using a fiberglass lid, and happened to touch underneath the panel that sits between the trunk lid and the bottom of the rear window. The visible upper side looked fine, so I was extremely surprised to find serious rust holes on the in the trunk portion of this. Guess that is another panel to replace.
And it has begun.
Russ
russosborne is offline
post #2 of 75 (permalink) Old 10-10-2011, 07:38 PM
Sweet, be sure to take plenty of pictures along the way to document the restoration, and post them here too.
post #3 of 75 (permalink) Old 10-10-2011, 08:52 PM Thread Starter
Let's see if this works.
I have a bunch of pictures on Image Shack, but I think it will be easier to post them from my home computer.
Here is a picture of the passenger side floor with the patch in orange.
Russ
Name:	pass floor pan patch.jpg
post #4 of 75 (permalink) Old 10-10-2011, 08:59 PM Thread Starter
one more, for now. doing it from Image Shack is a real pain.
Name:	lemans in garage 9oct2011.jpg
post #5 of 75 (permalink) Old 10-13-2011, 05:35 PM Thread Starter
No, haven't stopped working on it. Keep removing stuff, keep finding rust thru.
Got the interior almost completely stripped. Headliner, rear package tray, heater stuff on the inside, and that is about it. Then glass and rear bumper then off comes the body. I hope.
Have found quite a bit of rust in the front floor pans near the toe boards. Even another orange patch on the driver's side.
Oh, can anybody explain why a Lemans would have a Tempest tire load chart on the inside of the glove box door? I think all that is original, but have no way to be sure.
Here's a few more pics.
Russ
Name:	dash out of car 1.jpg
ID:	12577   Click image for larger version
Name:	drivers side no dash 2 better.jpg
ID:	12578   Click image for larger version
Name:	drivers side no dash 3.jpg
ID:	12579   Click image for larger version
Name:	gas pedal cables one for trans maybe.jpg
ID:	12580   Click image for larger version
Name:	glove box tempest 2.jpg
post #6 of 75 (permalink) Old 11-01-2011, 06:12 PM Thread Starter
OOPS, hadn't realised I haven't done an update here.
Well, got the body completely stripped except for the rear seat belts, which may end up having to stay, having problems getting them off, and the e-brake cable. Got all the mounts removed more or less, let's just say the ones still attached to the frame are not attached to the body anymore. Needing to replace panels makes life easier sometimes.
Hoping(expecting) to get the body lifted off this coming weekend. Just need to declutter the garage a big more so I can manuever the engine hoist. Got a tow strap to use with the hoist. Not sure where I am going to put the body though. May have to roll the chassis outside and get a tarp to cover it with for now.
So now let's see if I can attach pictures or not.
The first one is not my car, but is from Hot Rod, Street Rod, and Muscle Car Mega-site -- Hotrodders.com if I remember right. This is how I will be doing the bottom of the body.
Russ
Name:	a body car on rolltissorie.jpg
ID:	12783   Click image for larger version
ID:	12784   Click image for larger version
ID:	12785   Click image for larger version
ID:	12786   Click image for larger version
post #7 of 75 (permalink) Old 11-01-2011, 06:14 PM Thread Starter
Hey, no problems uploading the pictures.
here are some more. I need to go back and see what other pictures I have that I haven't put on here.
Russ
ID:	12788   Click image for larger version
ID:	12789   Click image for larger version
ID:	12790   Click image for larger version
post #8 of 75 (permalink) Old 11-02-2011, 09:41 PM
jetstang's Avatar
Keep it up, looking good.. Welders getting a workout I'm sure.
Burning rubber since 1982!!
jetstang is offline
post #9 of 75 (permalink) Old 11-03-2011, 03:18 PM Thread Starter
Well, it will be once I get started. Going to be an interesting learning curve for me. Might be awhile though, not sure when I will be able to start buying the replacement panels. Just got a bill for my recent heart tests. Almost $600. So much for my upcoming bonus check. :-(
You would think for that kind of money they could have at least found something wrong.
Russ
post #10 of 75 (permalink) Old 11-10-2011, 07:06 PM Thread Starter
more progress
Forgot to update here from last weekend.
Got the body off the frame and on jackstands for now in the garage. Frame is stripped except for the front suspension. Engine, trans, and rear end are sitting on the garage floor. Frame is still stuck outside on the driveway.
I didn't get any pictures of it all neat and organised, was running out of daylight thanks to the clock change and needed to get it all cleaned up.
Wasn't bad doing it by myself. I first used floor jacks to make sure it was completely disconnected from the frame, and then used the engine hoist and a tow strap wrapped around the floor.
2 things to note if you are going to do this.
1. Move the strap as far back as you can.
2. Center the strap on the hoist instead of having it lopsided.
Both of these I didn't do.
I don't think I have any pictures of the body on the hoist here at work, will try to post some from home.
Now to get a bottle of gas for the mig and hopefully some panels.
Russ
ID:	12900   Click image for larger version
ID:	12901   Click image for larger version
ID:	12902   Click image for larger version
ID:	12903   Click image for larger version
66 lemans convert rolling resto started facn8me 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 97 07-25-2012 09:12 PM
finally got a picture of the 70 Lemans russosborne 1964-1974 Tempest, Lemans & GTO General Discussion 18 04-29-2011 03:11 PM
Started!! Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 12 04-20-2011 02:21 PM
OK, Lets get started........ MAXXFJ 1964-1974 Tempest, Lemans & GTO General Discussion 19 10-15-2010 03:22 PM
Started the GTO today!! Rukee 1964-1974 Tempest, Lemans & GTO General Discussion 14 02-05-2010 12:36 PM
