Finally, working on the car again - Pontiac GTO Forum
post #1 of 198 (permalink) Old 01-20-2010, 08:31 PM Thread Starter
67 Basket Case Restorer
Too Many Projects's Avatar
Refresher: I had removed the rotten right cowl to frame mount last year and bought a replacement in OK. I cut the mount off the replacement section of floor today so I can attach it with screws to hold the body on the roto.
Both the mounting bolts were rusted off on the left side but the mount is solid. I had to cut out the rotten toe board to get access to the mount nuts from inside.
I cleaned it up as best I could and sprayed a lot of Eastwoods Rust Converter all over in the mount. Once it dries, I can recage the new nuts and the front will be ready for the roto.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
post #2 of 198 (permalink) Old 01-20-2010, 10:41 PM
66tempestGT's Avatar
nasty! glad to see things coming together for you.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #3 of 198 (permalink) Old 01-21-2010, 02:15 AM
Mike_V's Avatar
I love project threads
Mike_V is offline
post #4 of 198 (permalink) Old 01-21-2010, 08:22 AM Thread Starter
Lots more to come. The entire floor from those mounts to the tail lights will be replaced.
Mitch
1962 Impala SS
1938 Chev coupe
post #5 of 198 (permalink) Old 01-21-2010, 08:57 AM
Mike_V's Avatar
I can't even imagine how much work that's going to be. Way back when, in body shop class, I replaced a trunk pan and small section of floor - HATED IT.
Some people got it and some don't. But hey - this 'you work and I watch' is kind of nice
Mike_V is offline
post #6 of 198 (permalink) Old 01-21-2010, 09:16 AM
Quoted: 118 Post(s)
This is the hardest/worst part of the restoration. I do not have the skills,heart, or courage needed to undertake something of this magnitude. Give me a blown up engine or trans any day of the week!! On the upside, this '67 GTO is on the way back, and it's only UP from here! Nice going Mitch, and the photo's are greatly appreciated. A huge help to the hobby posting thresds like this!
Jeff
post #7 of 198 (permalink) Old 01-21-2010, 10:47 AM
Bobbyg's Avatar
Wow
Looking Good !!
Love the pictures.
Glad to see this come together. Can't wait to get there myself.
Bobbyg is offline
post #8 of 198 (permalink) Old 01-21-2010, 06:15 PM Thread Starter
Made a serious leap of faith today and cut out the right door post.....
Here's what it looks like on the inside....not much left of 5 layers of metal.
I gave up trying to get the outer rocker panel out of the cowl on the replacement piece. That sucker is welded to 3 braces inside the cowl. I would've had to drill ALL the spot welds out and completely dis-assemble it. The rocker is like new, so the new one will butt weld to it under the step plate. Not sure what I will do with the other side. It's in about the same condition and I didn't get a replacement cowl cutoff for it....
Here's the replacement mocked up for final fitting/trimming.
Mitch
1962 Impala SS
1938 Chev coupe
post #9 of 198 (permalink) Old 01-21-2010, 08:34 PM
Actually your patch looks like it fits better then I expected it would.
Are the three upper hindge bolt heads tourched off?
post #10 of 198 (permalink) Old 01-21-2010, 09:08 PM Thread Starter
Are the three upper hinge bolt heads torched off?
No, the bolts are there, just a little hard to see with the lighting.
I should have it near perfect in another hour. The 2 punches sticking out of the hinge bolt plates are my reference points for alignment.
Mitch
1962 Impala SS
1938 Chev coupe
Finally gonna get my car back crustysack 1964-1974 Tempest, Lemans & GTO General Discussion 8 10-22-2009 08:20 PM
My car is finally in the States (I think) CrazyAL 2004-2006 GTO General Discussion 4 06-26-2006 07:53 PM
Attachments are now working, 05GTO Gtoforum.com Site Help 0 03-27-2006 07:54 PM
Car&Driver finally talks nice about the GTO GrayGoat 2004-2006 GTO General Discussion 10 05-17-2005 09:37 PM
Center display not working SilverGoat Service, Maintenance and Technical Discussion 2 10-30-2004 10:09 PM
