Is a flywheel cover needed on a '64? - Pontiac GTO Forum
post #1 of 11 (permalink) Old 03-21-2011, 08:03 AM Thread Starter
daveh70's Avatar
Was at the mechanic yesterday. He said my car is missing a "flywheel cover". Do you guys know if the '64 is supposed to have one? If so, any reason mine may is missing and is a cover really needed? Here's a picture and you can see the open area with the flywheel bottom exposed.
Thank you
Dave Harris
1958 Buick Special 2 Door Riviera
1964 Pontiac GTO Post Coupe
2012 Shelby GT500 convertible
daveh70 is offline
post #2 of 11 (permalink) Old 03-21-2011, 12:27 PM
Thank you
Attachment 10623
yes there should be a cover there but other than visual it will not hurt to leave it off.
freethinker is offline
post #3 of 11 (permalink) Old 03-21-2011, 01:16 PM
Nah, as long as you don't mind rocks, crap, mud, miscellaneous road debris beating up the back side of your flywheel, getting up inside the bell housing, and generally making a mess of your pressure plate, starter ring gear, and throwout bearing.... then by all means leave it off
post #4 of 11 (permalink) Old 03-21-2011, 04:05 PM
Thor7352's Avatar
Dave,
My 64' Tempest (326 cid) came with a flywheel cover.
Here is how/why they are left off;
A mechanic will complete a clutch job/pilot bearing/main bearing etc. job. Then put everything back together, forgetting the thin little sheet metal guard that protects the flywheel. Once the car is all together they realize the forgotten part.... Shortly they realize the bell-housing to motor bolts must be loosened and the starter must be removed to get it in. Thats about the point they are left off and trashed or put in the trunk. If you remember to put it in during the first assembly attempt, they are easy to put in. If you forget and have to slip it in later, it can be a real pain...
-Thor
Thor7352 is offline
post #5 of 11 (permalink) Old 03-21-2011, 05:34 PM Thread Starter
daveh70's Avatar
Thanks for the responses. Did a little research and most are telling me that flywheel cover is not really needed because the car isn't driven every day and/or in bad weather. Unfortunately this part for the 64 is not reproduced. All things considered I may have to just forget about it. I'll keep my eye open though. Thanks for the input.
Dave Harris
daveh70 is offline
post #6 of 11 (permalink) Old 03-22-2011, 06:52 AM
allpawl66's Avatar
Use the 65 & up cover , just needs the tongue to be trimmed off at the bottom . If something gets in there while running it can crack the bellhousing .
allpawl66 is offline
post #7 of 11 (permalink) Old 03-22-2011, 11:36 AM
68GTO4004Spd's Avatar
Try "Billions and Trillions of parts" they deal with a lot of salvaged muscle car parts, they may have one. I personally have never delt with them, so I can't advise on how they are to deal with.
68GTO4004Spd is offline
post #8 of 11 (permalink) Old 03-22-2011, 06:22 PM Thread Starter
daveh70's Avatar
I have found someone via Hemmings that makes this part. I'll see how it goes and then can recommend if it works out.
Dave Harris
daveh70 is offline
post #9 of 11 (permalink) Old 03-24-2011, 04:51 PM Thread Starter
daveh70's Avatar
I'm going to try having this installed possibly tomorrow. Is this the right one for the 64?
Dave Harris
daveh70 is offline
post #10 of 11 (permalink) Old 03-24-2011, 04:58 PM
yes that looks like it should fit.
GTO Engine Cover/fuel rail cover CoreyTravis Exterior Discussions 29 02-13-2013 08:28 AM
SAP Pass. Rocker Cover Needed - Will even take damaged BanditDave Exterior Discussions 0 09-23-2008 12:34 PM
