Forward body bolts - Pontiac GTO Forum
post #1 of 5 (permalink) Old 02-08-2012, 12:53 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
Forward body bolts
All body bolts came out smoothly except the forward most bolts on the body (right behind front fender, not the core support) they are both spinning the capture nut despite my best efforts.
What is the easiest way to get to them?
Can I get to them from the front since both inner fenders will be coming back off? Would really like to avoid cutting my nice clean floor...
FlambeauHO is offline
post #2 of 5 (permalink) Old 02-08-2012, 02:59 PM
68greengoat's Avatar
Same problem I had. Ended up using a hole saw. Hopefully, you'll find a better way. I didn't remove any body panels since all I was doing was replacing bushings....
SOLD.....
462ci, 4spd
Performer Intake, Mild Cam
Pertronix Ignitor III
68greengoat is offline
post #3 of 5 (permalink) Old 02-08-2012, 03:34 PM
If it's the two I'm thinking about, you may be in luck. With the inner fenders out you should be able to get to the nuts on top through a couple of large square-shaped holes down low on the firewall, and grab them with a big pair of Channelocks or something similar.
BearGFR is online now
post #4 of 5 (permalink) Old 02-08-2012, 04:28 PM
69Goatee's Avatar
Those have large square access holes behind the inner fenders, no cutting required.
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
RESTORATION IN 1980...
NIN
69Goatee is offline
post #5 of 5 (permalink) Old 02-08-2012, 05:05 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
Thanks guys! That's what I'm talking about! Looks like I can definitely get to the inboards and maybe the outboard ones too!
Body bolts FlambeauHO 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 4 01-31-2012 09:39 PM
69 GTO with Body Bolts broken SPDMETL 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 05-09-2011 11:52 AM
one step forward and two back... Instg8ter 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 5 03-05-2011 09:53 AM
Body Mount Bolts mmag36 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 12-01-2009 09:34 AM
