Front coil spring compressor - Pontiac GTO Forum
post #1 of 5 (permalink) Old 11-06-2016, 07:17 AM Thread Starter
Quoted: 17 Post(s)
Getting ready to remove the front coils on my 69. Since the body is off the frame for restoration and the engine is out also, I can't use the normal method if jacking the lower control arm up against the weight of the car to compress the spring. Anyone have a recommendation on a good compressor to buy?? Thanks
greenjudge69 is offline
post #2 of 5 (permalink) Old 11-06-2016, 11:31 PM
shader's Avatar
Quoted: 9 Post(s)
The best and probably the safest internal compressor is made by OTC, but it is pricey at $200. Other ones go for $40 to $50. Try to find a USA made compressor. (Mine is an old KD Tools, USA). There are a lot of generic name ones available and I would guess most are made offshore, and the quality can be hit or miss. Just do a search for spring compressors and read the customer reviews if any. Toolsource.com has a USA made compressor for $47. I would say any compressor in the $40+ price range would suit your needs. I’ve seen some listed for as little as $17 and would stay away from those, though maybe some forum members had good luck with them.
shader is offline
post #3 of 5 (permalink) Old 11-07-2016, 06:45 AM Thread Starter
Quoted: 17 Post(s)
Thanks. I found out that advanced auto parts rents a good one for a very small fee. Thanks again
post #4 of 5 (permalink) Old 11-07-2016, 11:00 AM
shader's Avatar
Quoted: 9 Post(s)
Good to hear. My other suggestion was to rent one but didn't think of that till after my post. Have fun with the spring removal !
shader is offline
post #5 of 5 (permalink) Old 11-10-2016, 04:18 PM
64GTOConvertible's Avatar
Quoted: 17 Post(s)
Chain the frame to the ground and use the jack method?
64GTOConvertible is offline
66 gto front coil spring removal and replacement tonyli 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 05-17-2016 09:09 PM
67 Front Coil Spring Compressor cmm47172 1964-1974 Tempest, Lemans & GTO General Discussion 5 07-02-2014 09:41 AM
valve spring compressor in san diego purposebuiltsleeper Pacific 0 03-01-2013 04:33 PM
front coil spring installation Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 10-26-2010 08:54 AM
