FYI: 66 stock console floor shifter and powerglide parts - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-07-2011, 12:32 AM Thread Starter
torpedo51's Avatar
I'm putting a console in my car, and converting it from a column shift to a floor shift. It has a powerglide in it.
I couldn't find a single parts source that had everything needed for the conversion.
I got a GM shifter cable and trans lever from the Parts Place. I got the rest of the clips, pins, brackets from Ames.
I also got lucky and found a floor shift tilt column fully restored from a vendor that works through the Parts Place!
torpedo51 is offline
post #2 of 3 (permalink) Old 04-07-2011, 01:35 AM
Quoted: 23 Post(s)
If you need the shifter i have a restored one with new handle and button for two speed...PM me if interested
Instg8ter is offline
post #3 of 3 (permalink) Old 04-07-2011, 09:20 PM
factory trans in 66 is a ST-300, no powerglide. If you look for powerglide parts you will get lots of wrong items.
pontiac is offline
Question about 64 GTO powerglide shifter linkage Bryan H 1964-1974 Tempest, Lemans & GTO General Discussion 3 05-09-2013 10:24 AM
Is this a correct Shifter for a console 4 Speed xconcepts 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 7 08-13-2009 09:19 AM
Column shift to floor shifter jbranontn 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 01-03-2009 11:16 AM
