Gas gauge fix? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 07-28-2011, 08:42 PM Thread Starter
Gas gauge fix?
I have a 1970 GTO and I'm pretty sure the gas gauge is not correct ... So can I assume that the first thing to swap out is the sender unit in the tank?
Amigo-2k is offline
post #2 of 4 (permalink) Old 07-29-2011, 12:08 AM
69Goatee's Avatar
What is your gas gauge doing? I had a bad ground in the dash, would read E when lights were on.
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
RESTORATION IN 1980...
NIN
69Goatee is offline
post #3 of 4 (permalink) Old 07-29-2011, 07:17 PM Thread Starter
It is stuck on F. My shop replaced the sending unit and all it well now ....
Amigo-2k is offline
post #4 of 4 (permalink) Old 07-29-2011, 10:30 PM
69Goatee's Avatar
You can unplug the sender from the harness and test the gauge. On my 69, the plug is next to the trunk latch, driver side, it is the tan wire. With the key on, sender unpluged, the gauge will read full, then using a jumper wire ground the terminal on the harness plug to the body, tan also. The gauge should go to empty with the key still on. If it checks out, then check the sender ground. It is in front of the tank above the rearend, next to the passenger side tank mounting strap, make sure it has good contact, you might want to sand the area to bare metal. If this all looks good, then the sender might be stuck in the up position, I've seen it before. Or the sender is bad. Hope this helps.
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
NIN
69Goatee is offline
gas gauge mishap danthepontiacman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 15 10-03-2011 06:43 PM
gas gauge only works haff the time danthepontiacman 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 10-12-2009 10:05 AM
PLEASE HELP II - Only one thing left to fix - gas gauge 70455goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 10 07-30-2008 04:52 PM
Gas gauge got stuck on FULL 70455goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 04-17-2008 12:45 AM
fuel pressure gauge & boost gauge sdgoat Service, Maintenance and Technical Discussion 4 05-12-2006 09:34 AM
