Glove Box Door Adjustment? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-22-2011, 11:03 AM Thread Starter
Miami Ragtop's Avatar
Every time I try to open my glove box I get frustrated. The door does not pop
open when I press the lock button. I have to press the button and pry the door open with another finger. I Know there is a small spring on the hinge that is there for some reason but can't figure it out. Is there some type of adjustment needed on the lock or the door itself ? If anyone has solved this problem please let me know how. I am currently refurbishing the entire dash but feel like putting a 9mm to it.
Thanks,
Miami Ragtop
Miami Ragtop is offline
post #2 of 5 (permalink) Old 06-22-2011, 07:36 PM
There is a spring in the hinge pin at the bottom of the Glove Box door, yours maybe broken, or weak......common on 66 and 67. Eric
Eric Animal is offline
post #3 of 5 (permalink) Old 06-23-2011, 01:48 PM
Quoted: 23 Post(s)
do you have the two little rubber bumpers in it on the top, w/o those it will not POP open. also as Eric said if your spring is missing of weak it may catch
Instg8ter is offline
post #4 of 5 (permalink) Old 06-24-2011, 11:30 AM
adjust the door and the latch, it will pop open.
pontiac is offline
post #5 of 5 (permalink) Old 06-25-2011, 08:42 AM
66tempestGT's Avatar
lubricate the latch also. i had a trunk lid that no matter how i adjusted it wouldnt close without slamming. one little shot of wd-40 and it closed like butter.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
Glove box door sags PatrickNJ Service, Maintenance and Technical Discussion 7 03-19-2010 09:45 PM
Brake pedal assembly and glove box door question... JeepScrambler 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 3 10-24-2009 10:59 AM
