Got an issue with OEM hurst shifter - Pontiac GTO Forum
post #1 of 6 (permalink) Old 09-24-2011, 02:08 PM Thread Starter
xconcepts's Avatar
OK so I have been trying to reinstall the OEM hurst shifter. I pulled the quick shift and had no problem putting the OEM one one. However, something is wrong cause the center console will not fit.
I pulled the shifter adapter off thinking it was the reason, but I cannot get 2 holes to line up. So do I have the wrong shifter linkage or am I doing something wrong? It does appear that the floor was cut to move the linkage. BTW the chrome stuff is new heat dampiner I just put down.
xconcepts is offline
post #2 of 6 (permalink) Old 09-24-2011, 06:16 PM
that is not the correct shifter adapter. the correct one does not move the shifter that far left.
py also has them repo if you cant find one:
RPU200 1964-66 SHIFTER PLATE, 4-speed w/ nut......................$29.00
Has 2 small holes through big center cutout!!
RPU202 1967-72 SHIFTER PLATE, 4-speed w/ nut......................$29.00
RPU202A SHIFT PLATE- HURST COMP.........................................$20.0 0
RPU203 1968-72 AT SHIFTER PLATE...........................................$2 7.00
freethinker is offline
post #3 of 6 (permalink) Old 09-24-2011, 06:30 PM
Contact Pete Serio at Precision Pontiac, he will set you straight and can probably supply the parts you need!!! Precision Pontiac Home Page tell him Eric Aull (all) sent you! Eric
Eric Animal is offline
post #4 of 6 (permalink) Old 09-26-2011, 12:34 PM Thread Starter
xconcepts's Avatar
I got the plate ordered, but need to see if anyone knows if the bolt and plate that is missing from the shifter is a big deal. You can see where its missing in the 2nd and 3rd pic.
post #5 of 6 (permalink) Old 09-26-2011, 01:03 PM
the bolts are just bolts but the top bolt has a special flat nut that fits onto a slot. that will be hard to duplicate. buy it if you can.
post #6 of 6 (permalink) Old 10-27-2011, 09:39 AM
The plate on my 64 bolts directly to the trans and the shifter bolts to that.
roush05 is offline
Hurst shifter for '66 SANDU002 1964-1974 Tempest, Lemans & GTO General Discussion 2 04-20-2009 03:35 PM
Anyone Try A Hurst Shifter?????? lightspeed Drive train, suspension, alignment and brakes. 8 02-28-2009 08:24 AM
64 Hurst Shifter Koppster 1964-1974 Tempest, Lemans & GTO General Discussion 6 01-26-2009 09:35 AM
Hurst Shifter tjblake Drive train, suspension, alignment and brakes. 5 12-14-2006 09:16 PM
Hurst Shifter DaddySS Service, Maintenance and Technical Discussion 0 02-03-2005 07:30 PM
