GTO engine options - Pontiac GTO Forum
 1Likes
  • 1 Post By Rusty2010
post #1 of 3 (permalink) Old 04-08-2019, 10:43 AM Thread Starter
GTO engine options
I'm replacing the wiring harnesses in my 1967 GTO I've got a 400 CID with factory air. I noticed I need to know if I have ram air, high output and transistor ignition to order the engine compartment harness. How do I tell if I have those option is it by the VIN number?
Rusty2010 is offline
post #2 of 3 (permalink) Old 04-08-2019, 08:02 PM
Quoted: 348 Post(s)
You
You can't. You should be familiar enough with your car/GTO's in general to answer what you ask. A 1967 Service Manual is a real help for such things. Several good books on GTO's will also point out these differences.
I suggest you get the PHS documents for your car which will tell you what your car was originally ordered with from the factory. Important documents to verify your car.
Transistor Ignition was not common, points are what you most likely have unless someone had converted to electronic ignition.
HO would be evident by the large header type exhaust manifolds.
Ram Air would also be evident by the large header type exhaust manifolds and the special tub that sits on the carb and seals it to the hood - with the hood scoop being open.
Both of these options are not commonplace.
IF you decide to add aftermarket Ram Air/HO exhaust manifolds, then you may want to plan ahead for this as the engine compartment wiring to the starter is a little different.
You can also use the Google Custom Search in the upper right to search through past discussions to get a better idea of what these terms you ask of are about.
post #3 of 3 (permalink) Old 04-08-2019, 09:46 PM Thread Starter
Thanks PontiacJim, From what you wrote and info I've gotten from others I think I know I have a stock V8
PontiacJim likes this.
Engine Swap Options [email protected] 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 19 03-11-2019 03:10 PM
Engine options Caster1 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 49 09-17-2018 11:10 AM
Clutch options for 05 gto Robahr24 Drive train, suspension, alignment and brakes. 9 12-15-2009 06:40 AM
Customizing options 05 GTO Tail lights, nose, etc Borsig Exterior Discussions 2 01-31-2006 01:14 PM
Exhaust options for 05 GTO jwengel Service, Maintenance and Technical Discussion 3 06-17-2005 10:11 PM
