GTO-Vette hybrid - Pontiac GTO Forum
 2Likes
post #1 of 24 (permalink) Old 01-23-2019, 09:05 AM Thread Starter
chopolds's Avatar
Quoted: 8 Post(s)
GTO-Vette hybrid
An old co-worker of mine found a 67 GTO online and bought it sight unseen. Had it shipped from Oregon or Washington, to NJ and then called me to help him restore it. When I saw the car, I was shocked. It was rotted out so bad, even extending up into the underside of the hood, and the roof! I tried to dissuade him from building it, but he persisted. When I had an opening in my garage, we got it in, and started stripping it. We pulled the body off the frame, after reinforcing it with LOTS of tubing, and angle iron!
It's probably the worst car I've ever started on. And I've done cars from the 40's and 50's, that were pretty bad. I tried to get him to decide on how we were going to build it, as a full resto was not practical. Wrong engine and trans, no interior, broken, and missing glass, and trim, no front bumper, grill or surround. I presented many options to him, but we still had to start with buying and installing new sheet metal.
ID:	117305   Click image for larger version
ID:	117307   Click image for larger version
ID:	117309   Click image for larger version
chopolds is offline
post #2 of 24 (permalink) Old 01-23-2019, 09:14 AM Thread Starter
chopolds's Avatar
Quoted: 8 Post(s)
Pretty much anything available for the body shell had to be ordered. Full floors, trunk, quarters, rockers, even the roof. It looked as if it had been junked, and a car placed on top of it, it was so bad.
I'm not a pro shop, I do this as a "serious" hobby, adding to my tools and equipment over the last 40 years. So I've got some pretty good machines. This will help immensely on this build!
Since we had an open book on what type of car to build, I presented Freddy with options. Pro street (too dated), Pro touring (good but could be expensive), 60's street machine or gasser (a bit overdone nowadays), or Kustom (mostly body mods, lowered, perhaps chopped, change grill, taillights, etc). Fred couldn't make any decisions yet, so we proceeded to get the body back in shape.
ID:	117313   Click image for larger version
ID:	117315   Click image for larger version
chopolds is offline
post #3 of 24 (permalink) Old 01-23-2019, 09:17 AM Thread Starter
chopolds's Avatar
Quoted: 8 Post(s)
Floors, trunk, inner wheel wells, rockers, quarters, pretty standard stuff.
ID:	117319   Click image for larger version
ID:	117321   Click image for larger version
ID:	117323   Click image for larger version
chopolds is offline
post #4 of 24 (permalink) Old 01-24-2019, 08:45 AM Thread Starter
chopolds's Avatar
Quoted: 8 Post(s)
Don't know how many of you guys do this, or require your body shops to do it, but I prefer to lead in the quarter to roof joint, just like the factory did. Guess being a 50's custom guy has it's rewards.
ID:	117339   Click image for larger version
chopolds is offline
post #5 of 24 (permalink) Old 01-24-2019, 07:27 PM
Quoted: 33 Post(s)
WOW!! That's quite an undertaking. Your friend would've been better off buying one done with the money he'll have in that one! Kudos to you for helping him out. Looks like you have a good handle on it.
tjs72goat is offline
post #6 of 24 (permalink) Old 01-26-2019, 08:25 AM Thread Starter
chopolds's Avatar
Quoted: 8 Post(s)
Just fooling around, I had Fred pull one of the Vette's tail lights out of the car, and I made a hammerform to set it back flush into some sheet metal. Doing a trial run of how to form the tail light panel, if we decide to go that route. I kind of like it, it lets us do a sequential tail light set up. Might put a small break or peak through the center of the panel, not sure yet of anything.
For those interested in sheet metal fabrication: A hammerform is a great tool to make a panel with curved flanges, or complex shapes, on a relatively flat panel. You need to cut out 2 pieces of MDF, aluminum, or plywood, one conforming the shape you want, the other slightly larger. You clamp the sheet metal in between the 2 with as many clamps as you can, and then cut out anything you have to, or trim it to the desired overlap ( you can't have too much overlap on a complex shape as it will be hard to stretch/shrink the metal to fit. An open flange, it doesn't matter) The slowly hammer the metal over the edge of the form until it hugs it very tightly. Then unclamp and release. The form effectively holds the surrounding metal pretty flat, no distortion. You can do minor adjustments to the piece afterwards with a shrinker/stretcher tool if desired, or necessary. y (as in putting a second curve into a curved flange panel)
On this piece, we are trying 3 lights on each side. Might go with red, clear, amber lights if the owner decides what type of look he wants, instead of 3 red. Not our final piece, but we can mock it up in place and see if we like it.
ID:	117363   Click image for larger version
ID:	117365   Click image for larger version
ID:	117367   Click image for larger version
ID:	117369   Click image for larger version
1968gto421 likes this.
chopolds is offline
post #7 of 24 (permalink) Old 01-27-2019, 10:34 AM
1968gto421's Avatar
Quoted: 70 Post(s)
Really nice work. Thanks for the tips on the hammerform.
1968gto421 is offline
post #8 of 24 (permalink) Old 01-28-2019, 08:59 AM Thread Starter
chopolds's Avatar
Quoted: 8 Post(s)
The firewall had some damage, and rust too (What a surprise!). Since we're going custom on this, decided to smooth out the firewall by getting rid of the seams, and making a new bead rolled one. It has been welded solid, leaded in, and primered by now, have to get finish pics.
Thought about imprinting the Pontiac 'triangle' in the open area.
ID:	117381   Click image for larger version
ID:	117383   Click image for larger version
chopolds is offline
post #9 of 24 (permalink) Old 01-28-2019, 05:31 PM
Quoted: 347 Post(s)
Nice. What gauge steel are you using with the rolling dies? 20ga?
post #10 of 24 (permalink) Old 01-29-2019, 08:43 AM Thread Starter
chopolds's Avatar
Quoted: 8 Post(s)
Firewall, and floors I prefer to do in 16 or 18 Ga. Even sheet metal on older cars I do with 18 Ga. 20 seems to flimsy. If I could find the correct 19 ga. for body fab, I'd buy it! My roller can handle 16 ga, so better off with heavier steel.
chopolds is offline
hybrid 240/gto randall Member Introductions 2 08-24-2009 10:07 PM
Does the GTO have that economic shift mechanism the vette does? BrianV 2004-2006 GTO General Discussion 15 05-02-2006 03:55 PM
Vette Guy Helping Out A Gto Friend mph1972 Wheels and tires 7 04-14-2006 10:40 PM
Vette Rims/Tires on a GTO? StocktonRaider 2004-2006 GTO General Discussion 0 07-28-2005 07:23 PM
