Heater Hose routing - Pontiac GTO Forum
post #1 of 5 (permalink) Old 06-19-2014, 04:43 AM Thread Starter
RunninLeMans's Avatar
Heater Hose routing
My '64 motor had a heater hose return on the water pump and the supply coming out of a nipple threaded into the top of the intake manifold next to the thermostat. The '67 motor that I'm installing has a heater hose nipple on the passenger's side cylinder head at the rear. Should I just plug the bung on the intake manifold and use the cylinder head nipple for heater supply? Can't find a water circuit diagram for '67 anywhere online.
Thanks.
RunninLeMans is offline
post #2 of 5 (permalink) Old 06-19-2014, 08:36 AM
Take a good look at all the air and coolant passages in both the manifold and in the heads to make sure they match up with each other first. If they do, then yes - plug the passage in the manifold and use the one on the passenger side head. If they don't then you'll want to go ahead and locate a later model intake (which won't have the connection on the manifold).
post #3 of 5 (permalink) Old 06-19-2014, 08:43 AM Thread Starter
Thanks, Bear. The manifold is a '65+ Edelbrock P4B, so it is the correct one for the '67 heads, and I did check the passages to make sure they all lined up and the gaskets didn't cover any holes. Interesting to hear that the later manifolds didn't even have that fitting, I guess the P4B covers all the bases.
post #4 of 5 (permalink) Old 06-19-2014, 02:54 PM
Quoted: 117 Post(s)
I've never heard of an intake that would work on a '64 heads and also on later heads. Completely different runner design, with the '64 being longer. I would look very, very, closely. May I recommend a '68-'72 stock Qjet intake? They are cheap, fit perfectly, and will work better than the Edelbrock.
post #5 of 5 (permalink) Old 06-19-2014, 06:14 PM
rickm's Avatar
Quoted: 5 Post(s)
that threaded hole on that manifold is for a temp. guage. 65- up routing is all the same. waterpump nipple n pass. side head rear. you guys know ya cant mix '64 n '65 heads n intakes. your motor is a '67.
rickm is offline
68 GTO Windshield washer hose routing FlambeauHO 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 7 12-10-2013 03:05 PM
Vacuum hose routing for hideaways? petet 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 11-10-2013 10:42 AM
65 GTO Washer Fluid hose routing olde-goat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 02-03-2013 08:56 PM
Vacuum advance hose routing 4 speed mbergin 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 07-14-2012 08:48 PM
Quadrajet Vacuum hose routing.... ramairthree 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 10-15-2009 03:29 PM
