Heater hoses for a 69 GTO 400 4bbl with A/C PB PS - Pontiac GTO Forum
post #1 of 3 (permalink) Old 04-05-2016, 10:37 PM Thread Starter
dan woodland's Avatar
Quoted: 34 Post(s)
Hi all,
Does any one have a picture of the heater hoses at the firewall/back of the engine for the 69 Pontiac 400 with 4bbl, A/C PB PS?
I'm trying to figure out if I need to order a formed hose or if the "by the foot" hose is correct.
I currently have three hoses, one runs from the firewall to the water pump on the passenger side, the second also on the passenger side is a short run to a valve on the front of the heater box with the third originating from that same valve going to the area at the back of the intake.
As always many thanks in advance, Dan
*67K miles... Under Construction* :)
dan woodland is offline
post #2 of 3 (permalink) Old 04-06-2016, 08:35 AM
Correct ribbed heater hose, cut to match. only original NonAC cars had the short molded hose.
Buying the correct ribbed black heater hose, don't buy the old hose that is stamped GM-GM-GM, it's incorrect.
post #3 of 3 (permalink) Old 04-07-2016, 08:05 AM Thread Starter
Quoted: 34 Post(s)
Many thanks PH. Dan
68 GTO Left/Right Rear Flex Brake Hoses mwatson1647 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 2 05-08-2015 06:50 PM
heater hoses Jared 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 06-12-2013 08:42 AM
65 GTO Heater Box Heater Core Blower Motor Questions WideTrack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 02-06-2013 07:45 AM
1973 GTO power steering and fuel hoses joesweeting 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 4 09-30-2012 01:35 PM
1972 400 2bbl to 4bbl Conversion jpdog357 1964-1974 Tempest, Lemans & GTO General Discussion 13 10-31-2009 03:00 PM
