Hole for shifter - Pontiac GTO Forum
post #1 of 9 (permalink) Old 10-20-2010, 05:59 AM Thread Starter
Hole for shifter
I recently replaced the floor pan on my 66, the old one was destroyed. Now hatI have the new one in, does anyone have photos of what the 4 speed shifter hole looked like? I know he location, but i want to cut the hole the way the factory did. Thanks
Sloan66 is offline
post #2 of 9 (permalink) Old 10-20-2010, 08:09 AM
My `65 looked like they cut the hole with a tourch!!
post #3 of 9 (permalink) Old 10-20-2010, 02:52 PM
Here is a picture of my 66. It may be give you an idea of what NOT to do because it looks kind of hacked up to me!
Name:	GTO shifter.jpg
MichaelG is offline
post #4 of 9 (permalink) Old 10-21-2010, 09:48 AM
Quoted: 118 Post(s)
If you get the shifting porch and place it on the tunnel, it fits in only one place. my experience is limited to original floor cars. The holes on all of mine have been very neatly cut. No photo, dont' want to tear my car apart. (plus I can't post photo's due to my own ignorance). Get the shifting porch (doghouse) and try it out. I used a die grinder with a cut-off wheel to do a 4 speed conversion on a friend's '66, and it turned out very clean and dead on. good luck...........
post #5 of 9 (permalink) Old 10-21-2010, 09:58 AM Thread Starter
Thanks Geeteeohguy, any idea the shape of the hole? Was it square, round? About what size. I have the porch, and know the location, just not sure how the hole is suppose to look. Want to make it look original, have nothing to go by.
Sloan66 is offline
post #6 of 9 (permalink) Old 10-21-2010, 12:15 PM
Quoted: 118 Post(s)
If I remember correctly, it follows the shape of the porch/doghouse. You need to draw an outline around the doghouse, and then cut the pan about one to 1.5 inches inboard of your outline. The corners are rounded, not sharp angles. Sharp angles (square) will promote weakness and tearing. I'm certain someone can post a photo of an original car that's apart that has an original floor pan with stickshift....as I said, I'm not willing to tear the interior out of my '65 to take a look...remove the seats, carpet, console, porch, etc.....
post #7 of 9 (permalink) Old 10-21-2010, 12:19 PM
Check out my restoration pictures, the 4th one shows the hole faily well.
post #8 of 9 (permalink) Old 10-21-2010, 08:09 PM Thread Starter
Thank so much! Can't say how much i appreciate this website.
Sloan66 is offline
post #9 of 9 (permalink) Old 10-22-2010, 08:01 AM
67 Basket Case Restorer
Too Many Projects's Avatar
Of all the pics I have of my car, none show the shifter hole. I did remove the porch a while back for the floor replacement and the hole follows the porch fairly close, like geeteeohguy said. If you mark the inside of the porch and leave a 3/4" flange inside for the sealer, it will be good.
Mitch
1967 Camaro ss/rs 350
1966 Chevelle SS 396
1966 Chevelle Malibu
1970 Chevelle SS 396
1962 Impala SS
1952 Chev 2 ton flat bed
1938 Chev coupe
Too Many Projects is offline
65 Firewall hole identification please injn37 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 09-01-2009 06:23 PM
Hole in my interior? baron_iv Interior Discussions 14 01-02-2007 10:43 AM
Out of the hole pageme136 2004-2006 GTO General Discussion 7 04-17-2006 01:00 PM
Hole in Carpet btchplz Interior Discussions 15 02-17-2006 08:40 AM
Another 6.0L in the Car Hole!!! RedRacer 2004-2006 GTO General Discussion 21 12-02-2005 08:20 PM
