horn mystery - Pontiac GTO Forum
post #1 of 8 (permalink) Old 11-12-2010, 01:55 PM Thread Starter
RIP (12/27/60-7/18/15)
Topkat's Avatar
horn mystery
I have both horns on the bench.
When I apply 12VDC neither one works!
The contact is totally clean and I have a good ground.
I tried a battery charger and figured it didn't have enough oomph.
But I tried both on my boat battery (that's fully charged)
Still nothing
I realize both COULD indeed be bad.............but WTF????
(I'm an avionics Tech so this really po's me) LOL
What am I missing???????????
grrrrrrrrrrrrrrrrrrrrrrrrrrrrr X 10
thanks as always.
Topkat is offline
post #2 of 8 (permalink) Old 11-12-2010, 02:19 PM
Ground the mounting base and apply 12v+ to the spade terminal, should work. If not, drop it on the floor and try again, but more then likely, it's junk.
post #3 of 8 (permalink) Old 11-12-2010, 05:41 PM
Is it possible that you were last driving the car with only one horn operating thinking that it was two?
dimitri is offline
post #4 of 8 (permalink) Old 11-12-2010, 05:59 PM Thread Starter
Topkat's Avatar
I never drove the car. It was/is in pieces.
Topkat is offline
post #5 of 8 (permalink) Old 11-13-2010, 12:06 AM
66tempestGT's Avatar
if they came out of the same river as the core support you probably need new.
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
post #6 of 8 (permalink) Old 11-13-2010, 10:48 PM
Eric Animal is offline
post #7 of 8 (permalink) Old 11-14-2010, 12:10 AM
jetstang's Avatar
Avionics, Pointy head?? That's what they are called in the AF..
Burning rubber since 1982!!
jetstang is offline
post #8 of 8 (permalink) Old 11-16-2010, 12:54 PM Thread Starter
Topkat's Avatar
Mwaaaaaa. I got the smaller one working by removing the torx adjusting screw and soaking the beast in "watch cleaning solution".
I pressed a small screwdriver into to hole to move the metal strip a few times and applied power. With my cheezy 12VDC power supply all it did was buzz. Hooking it to a car battery,it at first made a mornfull sound. On subsequent applications of power it started working better.
Now it's good to go!
The other is still flat line.........lol
Topkat is offline
Mystery coolant leak need help figuring it out.... pctek Service, Maintenance and Technical Discussion 21 10-30-2010 06:10 PM
Block Code ID Mystery charlie4170 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 02-16-2010 07:57 AM
Mystery engine in '66 GTO convertible Exit32 1964-1974 Tempest, Lemans & GTO Complete Engine Compartment Discussion 17 04-01-2009 11:21 AM
Mystery Manifold! PEARL JAM The Lounge 8 03-25-2007 05:35 PM
Mystery Beeps AGR81 2004-2006 GTO General Discussion 22 09-22-2005 09:05 AM
