How do I remove these trim pieces? - Pontiac GTO Forum
post #1 of 4 (permalink) Old 04-22-2014, 07:54 PM Thread Starter
1968 Q8's Avatar
They basically run the parameter of the headliner and around the rear windshield.
1968 Q8 is offline
post #2 of 4 (permalink) Old 04-23-2014, 06:25 AM
That is called window lace. They just pull off. Start by removing the inner pillars moldings, sunvisors, rearview mirror, shoulder harnesses and sail panels. Then remove the window lace on the side windows, windshield and rear window. The outer edge of your headliner will then be exposed. Did you find your new headliner? Matt
Matthew is offline
post #3 of 4 (permalink) Old 04-23-2014, 06:31 AM
Forgot to add... you will need to remove the coat hangers and dome light as well. Disconnect the battery for removing the dome light. Matt
Matthew is offline
post #4 of 4 (permalink) Old 04-23-2014, 12:11 PM Thread Starter
1968 Q8's Avatar
Great, thanks Matt.
No luck on the headliner yet, the color is available, but not the pattern. Still looking, if I don't find one, the only other option is to buy a white taffeta kit and have it dyed Ivy Gold, but I'm a little apprehensive to do that, don't want any inconsistency in the dye process.
Appreciate the help!
1968 Q8 is offline
69 Grill trim pieces SANDU002 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 0 08-20-2013 05:30 PM
64 Post Trim - how to remove jvongray 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 10-14-2011 09:28 PM
How do I remove the door vent trim & instrument cluster trim? batmans Interior Discussions 13 05-11-2011 06:11 PM
painted interior trim pieces gtogooch Interior Discussions 2 01-08-2010 07:00 PM
