How do I replace the door locks? - Pontiac GTO Forum
post #1 of 7 (permalink) Old 01-17-2012, 09:04 PM Thread Starter
xconcepts's Avatar
So after getting back from Afghanistan in early Sept I can't find the original door keys. So how do I remove the locks to replace them?
xconcepts is offline
post #2 of 7 (permalink) Old 01-17-2012, 10:22 PM
The doors ought to be keyed the same as the ignition, but to remove the lock cylinders - remove the inner door trim panel, roll the window up, look at the back side of the lock. You should see a clip that's "forked" over the back of the lock cylinder. Slide that clip off and you should be able to pop the cylinder out. You might have to unscrew the latch mechanism (the part that engages the striker) to get some freedom of movement to disengage the linkage rod to the cylinder.
post #3 of 7 (permalink) Old 01-17-2012, 10:41 PM Thread Starter
xconcepts's Avatar
Sounds pretty easy, there not keyed the same as my ignition cylinder since someone stole my keys last year and I replaced the ignition cylinder.
post #4 of 7 (permalink) Old 01-18-2012, 07:58 AM
I had NAPA redu my locks so they all (except the trunk) need just 1 key. Might be an option for you too.
post #5 of 7 (permalink) Old 01-18-2012, 08:12 AM
.....then keep a spare on a string around your neck, like when we were little (house key)..
Eric Animal is offline
post #6 of 7 (permalink) Old 01-18-2012, 09:34 AM
67/04gto's Avatar
personal i would replace the the ign and door lock so you just have 1 key for both,when i got my 67 i have 4 keys for the car.so i replaced it so i only have 2
67/04gto is offline
post #7 of 7 (permalink) Old 01-18-2012, 11:32 AM Thread Starter
xconcepts's Avatar
I had a spare, it was lost by my SO when I was gone. She doesn't remember it though.....
I called NAPA, they don't rekey here, I'll have to check with a locksmith or something to have the ignition and doors the same.
Door locks johni53 Interior Discussions 2 04-20-2011 10:58 AM
Power Door Locks ICE05 Interior Discussions 8 12-31-2010 06:41 AM
04-05 GTO auto door locks EEZ GOAT Service, Maintenance and Technical Discussion 5 05-13-2009 04:54 AM
Door Locks on my 06 FD Prez Interior Discussions 8 10-31-2008 12:42 AM
Door Locks SasdawgGTO 2004-2006 GTO General Discussion 7 11-12-2004 04:21 PM
