how I removed a broken body bushing bolt - Pontiac GTO Forum
 1Likes
  • 1 Post By Nicholas
post #1 of 4 (permalink) Old 02-11-2019, 07:22 PM Thread Starter
clevelandpartsguy's Avatar
So I managed to remove 7 of the 8 body bolts on my 69 I'm restoring, but I did break the one that is under the drivers door. I thought I'd post this here for my friends as I had to think how to go about doing this and while some posts talked about cutting the floor from above I could not find any pictures to show exactly how. So this is how I did it. I marked it out and cut the U-shape hole in the floor staying away from the factory plug welds holding the floor to the floor-brace and bent it back. Next I squared off the top of the 7/6"-14 bolt sticking out, so that I could drill a hole through the center. The hole will allow for the material to move a little due to thermal expansion and contraction during/after welding, hopefully moving enough to help break free the rusted threads. Cleaned up the threads and threaded the 7/16"-14 nut all the way down, and backed off about 1/2 turn to allow for wiggling the bolt down/up. Once I got a good ground on the workpiece I welded the nut in place. Then I started with an open end wrench wiggling the bolt up/down a little at a time each time moving farther and farther, spraying penetrating oil down into the threads to help. After about 3 minutes of this BINGO ! Worked like a charm I hope this helps someone down the line.
ID:	117593   Click image for larger version
ID:	117595   Click image for larger version
ID:	117597   Click image for larger version
ID:	117599   Click image for larger version
clevelandpartsguy is offline
post #2 of 4 (permalink) Old 02-12-2019, 04:34 PM
Quoted: 36 Post(s)
Interesting. Thanks for sharing, Nicholas.
clevelandpartsguy likes this.
Nicholas is offline
post #3 of 4 (permalink) Old 02-13-2019, 09:08 PM
Quoted: 33 Post(s)
I was there too. But, my cage broke and I ended up cutting it out and pulling nut. Put a new nut in and welded a new cage around it. You got lucky.
tjs72goat is offline
post #4 of 4 (permalink) Old 02-13-2019, 09:26 PM
the65gto's Avatar
Quoted: 12 Post(s)
Good job, I have one that is broken off also. I think I will try your method.
the65gto is online now
Body bolt and bushing removal 2ocnorb 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 3 10-28-2018 10:58 AM
74 GTO Exhaust Manifold Broken Bolt and Pulling Heads Red74Goat 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 9 05-07-2016 05:11 PM
Removed broken starter found something else broken-is this bad? timholio 1964-1974 Tempest, Lemans & GTO Exhaust, Suspension, Alignment, Fuel Tank and Brakes. 5 05-12-2014 01:25 AM
rear bumper bolt broken off Mr_Roboto 1964-1974 Tempest, Lemans & GTO Complete Exterior Body 6 06-27-2013 04:49 PM
Broken bolt in thermostat housing. jrgirl88 Service, Maintenance and Technical Discussion 4 09-16-2010 12:00 PM
