how much interior insulation for 66 - Pontiac GTO Forum
post #1 of 3 (permalink) Old 06-26-2015, 01:55 PM Thread Starter
Hi, it is time to start insulation my lemans. I'm thinking about using Eastwoods Thermo-coustic Sound Deadener & Heat Barrier. I want to do floor from the toe boards to under and behind the rear seat. Also the roof, doors and kick panels. A bulk pack for $160 Includes 9 18"x30" sheets to cover a total of 33.75 sq. ft. Will that be enough for what I plan to do or should I order more / less? Thank you in advanced.
woolsey10 is offline
post #2 of 3 (permalink) Old 06-27-2015, 07:41 PM
That's what I used on my 69, and I like it. If you're making a lot of power and/or running headers, you might consider adding extra material to the firewall and the front part of the floor pan over the collectors.
post #3 of 3 (permalink) Old 07-05-2015, 08:13 PM
bobby326's Avatar
I used GT sound deadning. Hot it off ebay. Just search sound deadning and it will pop up. 100 sq feet 2-50ft rolls of 80 mill for 200. I did from my fire wall back seat and doors and only used one roll. If your doing your roof to you will be around 70sqft so you will need the 100sqft. Comes with tape and roller. Came out good. Im hsppy with it
bobby326 is offline
Firewall insulation question. Oldeboy 1964-1974 Tempest, Lemans & GTO General Discussion 5 01-15-2014 11:38 AM
under hood insulation ... jbach 1964-1974 Tempest, Lemans & GTO General Discussion 6 09-13-2013 10:46 PM
65 Tripower Hood Insulation timmyg 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 08-20-2013 11:13 AM
Foam Insulation canadianGTO 2004-2006 GTO General Discussion 1 02-15-2010 01:37 PM
Insulation on hood sdgoat 2004-2006 GTO General Discussion 2 04-02-2006 06:41 PM
