How to remove 1970 Center console? - Pontiac GTO Forum
post #1 of 6 (permalink) Old 07-25-2011, 07:29 PM Thread Starter
I have a 1970 GTO that I want to replace the slider dust cover for the auto-shifter. I removed 2 screws and 2 bolts (from a bracket) and the console is loose but the shifter (with the knob off) still wants to come with the console. The shifter will even move side to side with the console (I'm guessing something is not connected ...).
Amigo-2k is offline
post #2 of 6 (permalink) Old 07-27-2011, 11:11 PM
69Goatee's Avatar
I changed my stock shifter for a Dual-Gate in my 69 years ago, so I am kinda fuzzy on how the stock one mounts. I know the trim piece(chrome with woodgrain sticker on 69) that covers the shifter is held in with spring clips and pops out. I think the shifter is bolted to the console under there. It is also bolted to the trans tunnel with two brackets, sounds like yours may be loose.
1969 GTO
NUMBERS MATCHING
PAWN SHOP FIND
1947 MGTC
GRANDFATHER STARTED
RESTORATION IN 1980...
NIN
69Goatee is offline
post #3 of 6 (permalink) Old 07-28-2011, 11:19 AM
Pontiacpurebrred's Avatar
Hope this link works and I hope it helps. If not search google books for GTO Restoration Guide. It gives step by step breakdown of the automatic console.
Pontiac GTO Restoration Guide, 1964-1972 - Google Books
Pontiacpurebrred is offline
post #4 of 6 (permalink) Old 07-28-2011, 12:08 PM
pop off the trim piece and there are 4 bolts under there.
freethinker is offline
post #5 of 6 (permalink) Old 07-28-2011, 08:38 PM Thread Starter
God bless the internet ... I stuck my hand in the shifter plate and pulled it right up .... DOH!
Amigo-2k is offline
post #6 of 6 (permalink) Old 01-04-2014, 01:54 PM
Amigo
Did you end up having to remove the console or just the faceplate? I am asking because I need to do the same thing .
Tks
Tweety70 is offline
66 Center Console xconcepts 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 7 05-30-2017 08:43 AM
Center console '66 Miami Ragtop 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 5 06-13-2011 08:17 AM
Center console lock SIXT5GTO 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 02-15-2011 06:12 PM
Remove center councel to install Lou Short Shifter GTOFEVR Interior Discussions 4 06-03-2010 08:29 AM
center console. how do i get it off? EEZ GOAT Service, Maintenance and Technical Discussion 2 07-03-2007 07:41 AM
