Installing Harmonic Balancer - Pontiac GTO Forum
post #1 of 3 (permalink) Old 07-09-2011, 02:18 AM Thread Starter
Hey guys, I'm new on this forum and I'm also pretty new to engine building. I have two experienced guys that I'm working with on this project though and they're guiding me through it. Anyway, what I'm working with is a 1975 Pontiac 350 cubic inch engine and I need to reinstall the new balancer I bought. I rented a harmonic balancer removal/installation tool but the problem is that it's designed for balancers that don't have the center bolt for the balancer recessed about an inch or so into the balancer itself. I'll try and get some pictures up but basically I'm wondering if there are any other ways to get it on. I've heard you can use the center bolt to seat the balancer but I don't wanna break a wrench doing so. Any insight would be appreciated, thanks!
Nickel45 is offline
post #2 of 3 (permalink) Old 07-09-2011, 06:00 AM
pontiac balancers go on and off with hand pressure. to install it just push it on until it seats then run the bolt up tight to specs.
freethinker is offline
post #3 of 3 (permalink) Old 07-10-2011, 12:04 AM
no tool necessary. It should slide on if crank and seal have some white grease on it. Also, be sure key is seated flat. do not use bolt to pull up balancer into position. Torque is 160 ft lbs and no less. Air Impact is not sufficient for full tightening up to spec.
pontiac is offline
Harmonic Balancer? SWOOSH 1964-1974 Tempest, Lemans & GTO General Discussion 8 05-09-2011 06:50 PM
Harmonic Balancer YellO5LS2 Engine Discussions 1 01-20-2011 09:33 PM
harmonic balancer 68gtohawk8369 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 04-27-2010 01:30 AM
harmonic balancer/underdrive Richtenb Engine Discussions 4 02-24-2010 07:34 AM
