Intake manifold issues/question - Pontiac GTO Forum
post #1 of 6 (permalink) Old 05-19-2012, 04:45 PM Thread Starter
Pontiacpurebrred's Avatar
I will start by saying I would like to keep the original intake and not do a great deal of modification to it. I want to keep a more stockish look to the engine so I didn't want to hack this up. I know I could cut the water cross over off and use a separate piece, I'd prefer not to.
I was cleaning some parts this weekend and took the water neck off my intake to clean it all up and one of the bolt heats snapped of and I was left this.
It looks like this stud has been welded in here.
Any options or am I looking for a new manifold?
Thanks!
2005 GTO Daily Driver
1969 Custom-S Project car
1971 GTO 455 in process of rebuild TH400 NEED A NEW REAREND!!!
Pontiacpurebrred is offline
post #2 of 6 (permalink) Old 05-19-2012, 07:11 PM
Icefan71's Avatar
Did you try vice grips or a stud remover? Spray some wd40 on it, give it a couple of wacks with a hammer. Maybe let it sit a while or overnight. Then try and unthread it. If you have a torch you can heat the area around the bolt, then try unthreading it. Or worst case, cut off whats sticking out, then drill out the rest and retap the hole the next larger size.
Icefan71 is offline
post #3 of 6 (permalink) Old 05-19-2012, 09:53 PM
chuckha62's Avatar
Quoted: 18 Post(s)
I say your best bet is heat. Warm the manifold around the bolt and use vice grips to get it out.
chuckha62 is offline
post #4 of 6 (permalink) Old 05-20-2012, 07:00 AM
Looking closely at your photos, it -does- sort of look like there's a weld bead or perhaps some sort of soldering/brazing that's been done there. If you've got an air or electrical cut-off tool, the kind that use a thin abrasive disc, you might try -carefully- applying it to those areas to see if you can remove/cut through them and free up the stud. A Dremel-type tool with a cutoff wheel might make it easier. If worse comes to worse, grind the top of it flat, drill it out, and re-tap the hole.
post #5 of 6 (permalink) Old 05-20-2012, 08:30 AM
with both.......very do-able with patience.
Eric Animal is offline
post #6 of 6 (permalink) Old 05-21-2012, 07:59 AM Thread Starter
The stud is out! (wow that sounds bad)
I used the torch idea and heated it good and actually blew the welds out - I think they may have threaded it with JB Weld or something similar, not an actual weld, or perhaps it was just nasty dirty like so many other components on this engine.
Got her hot, blew the crap outta there and then threaded it out with a vice grip. Threads all look good.
I will have the base coat of 1200 degree silver later this week. I will post pictures in my resto thread, lots getting done again. I am pleased.
Thanks again for all the help guys.
Intake Manifold question Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 12-26-2010 04:02 PM
Ls6 intake manifold question... stealth gray goat Intake and Exhaust Discussions 3 12-17-2009 02:12 PM
'66 Gto Intake Manifold Question take5 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 2 10-02-2009 08:55 PM
