Let the wet sanding begin... - Pontiac GTO Forum
post #1 of 29 (permalink) Old 04-04-2011, 09:40 PM Thread Starter
Quoted: 23 Post(s)
temp got up to around 60 today so i laid on a few more coats of high build and guide coated the whole car with 180 laser straight, shot one more heavy coat to wet sand out. Also got my trunk battery set up finished and ready for install. have work the rest of the week so motor may be going in this weekend so if i ding it i can still touch up before paint. Getting closer.....
Instg8ter is offline
post #2 of 29 (permalink) Old 04-04-2011, 09:52 PM
I HATE SANDING !!!!!!!.....looking good bro. post some pics while you are blocking it out! Eric
Eric Animal is offline
post #3 of 29 (permalink) Old 04-04-2011, 10:09 PM
jetstang's Avatar
Hell yeah!! good job. Nice to see it in primer..
Burning rubber since 1982!!
jetstang is offline
post #4 of 29 (permalink) Old 04-04-2011, 11:34 PM Thread Starter
Quoted: 23 Post(s)
hard sanding is all done E, guide coated it all after two double wet coats and started sanding a quarter to see how it looked. Well once i started there was no way i was gonna leave it a blotchy mess any longer so i buckled down and got-r-done. hopefully get motor in this weekend and work on the wetsanding a panel at a time back to front at my leisure, hoping to get it in color by the end of the month and start re-assembly on schedule for May driving season...have just kept telling myself what i tell my re-modeling customer when i am demo'ing their kitchen...have to make it look like crap before i can make it look pretty. Yes Jet it's great to see it all back in one color at least, body line all straight and sharp, got that door cowl gap back in spec, cannot wait to see it in the Bahama Blue, should pop nice....i will take a vid if we get the motor up and running, installed the 2 1/2" exhaust over the weekend, i always notice when the tailpipes look off kilter on the 66-67's, i like them to be right below the reverse lights, never realized what a pain in the A** it would be to get them straight and even. What kinda tips are you guys planing on using?
post #5 of 29 (permalink) Old 04-05-2011, 06:50 AM
It is true....They do look worse before they look better!! I am going with headers 2 or 2 1/8 primaries into 3 1/2" collectors.....3"pipes, muffs, 3"tails to "splitter tips" like on a 65 GTO........thats the plan anyway....
post #6 of 29 (permalink) Old 04-05-2011, 07:25 AM Thread Starter
Quoted: 23 Post(s)
i like the splitters down tips also E, unique to Pontiacs
post #7 of 29 (permalink) Old 04-05-2011, 08:43 PM
come on. make that extra step. take the mirror off. that will be a spot that will be difficult to shoot around. also take some 2/4 pieces and wedge the trunk hinge down. they will get in the way of shooting inside the rear window sail panel.
freethinker is offline
post #8 of 29 (permalink) Old 04-05-2011, 09:52 PM
jetstang's Avatar
I'm sure he hasn't just got there yet, work is work and everything takes time.. Nice progress!!
jetstang is offline
post #9 of 29 (permalink) Old 04-06-2011, 06:50 AM Thread Starter
Quoted: 23 Post(s)
Yes Free those Details will be taken care of, was not planning on spraying it when i got up as our weather here has been all over the map, but i decided to take advantage of a narrow window, and had to bust A** to mask, spray 2-coats, guide and block, and spray again in a 6 hour span as i am a one man show on this one. And the mirror is un mounted and when i sprayed it i pulled it away and hung it from a wire on the ceiling.....thanks for the suggestions. I do realize i am not a pro and am just trying to give myself every chance of having a "good" job on it with my limited experience and conditions. It's not a 6000.00 paint job for the simple reason i don't have 6k to throw at it and the whole rest of the car has only about that much into it....it is by all accounts a "budget Build" so what if it ends up a 10 footer, It's MY 10 footer and i can blame no one but the guy who did all the work...ME! Find that much more rewarding than throwing 20 thousand at a car that at best will be worth 10-12 and having no connection to it other than writing a check and pressing the gas pedal....
post #10 of 29 (permalink) Old 04-06-2011, 09:30 AM
Looks good man!!
Are you planning on running two batteries?
do I even have the right radiator to begin with? denf221 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 04-22-2010 05:53 AM
65 gto final sanding before paint crustysack 1964-1974 Tempest, Lemans & GTO Paint Shop Discussions 3 04-24-2009 01:17 PM
Wet Sanding jbranontn 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 11-14-2008 08:43 PM
Let the flamming begin.... GTODEALER The Lounge 41 01-05-2006 11:17 AM
Let the mods begin dealernut Service, Maintenance and Technical Discussion 12 12-16-2005 05:27 PM
