Limited slip - Pontiac GTO Forum
post #1 of 21 (permalink) Old 02-26-2012, 03:14 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
Limited slip
Anyone know of an inexpensive limited slip unit I can put in my 10 bolt? Remember that I am not racing or looking for anything crazy just an inexpensive unit.
FlambeauHO is offline
post #2 of 21 (permalink) Old 02-26-2012, 05:12 PM
ARB Air Lockers: Best Prices for ARB Air Lockers Compressor Pump
These are cool. I think it gives you the best of both worlds. Not sure if they have an application for the Pontiac 10 bolt though.
post #3 of 21 (permalink) Old 02-26-2012, 06:11 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
Really looking for a cheap LSD / posi not a locker
post #4 of 21 (permalink) Old 02-26-2012, 06:18 PM
Quoted: 23 Post(s)
Cheapest would be to find a used limited slip carrier, need to know what gear you have in it now to see which series carrier you will need to find. still talking around 500-750 with carrier, ring gear and pinion (if you change gearing), install kit and bearings.
Instg8ter is offline
post #5 of 21 (permalink) Old 02-27-2012, 03:53 PM
Quoted: 99 Post(s)
Or go with an Auburn LSD unit. Strong or stronger than stock, and reasonable ($400-$800. If it were me, I'd be scouring Craigslist for a good used 8.2 unit. I was given an 8.2 posi out of a '69 for free.....because it was a 2.56 ratio. (which I wanted to run, anyway). You never know.
post #6 of 21 (permalink) Old 02-28-2012, 03:42 PM
68GTO4004Spd's Avatar
I bought this one from a guy on Performance Years forum for $800, 68 GTO Nodular 4 pinion with 3:55 gears, exactly what I was looking for. For the first time in 30 years I will have the rear end and gear ratio this car is supposed to have. Don't even have to clean it or paint it.
ID:	14096   Click image for larger version
ID:	14097   Click image for larger version
68GTO4004Spd is offline
post #7 of 21 (permalink) Old 03-11-2012, 12:13 AM
not possible to find a cheap one.
pontiac is offline
post #8 of 21 (permalink) Old 03-11-2012, 12:57 PM
I tend to agree - unless you're both very patient and very lucky.
That's Brian's (Instg8er's) department!!
BearGFR is online now
post #9 of 21 (permalink) Old 03-11-2012, 03:35 PM
Quoted: 99 Post(s)
Under $1000 is cheap, when all things are considered. You'll do it once, and it'll be done right with quality parts that will last as long as you own the car. You get what you pay for, usually.....
post #10 of 21 (permalink) Old 03-11-2012, 09:24 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
I have seen innumerable drop in LSD units in the 400 dollar range, I just wanted to see if there were any other alternatives as my project is already over budget. It will have to wait with some other items such as the small chrome parts. Thanks for the input.
limited slip problems? Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 1 07-07-2011 08:22 PM
Limited Slip and No Slip Differentials....Whats the difference? xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 9 06-16-2011 07:18 AM
65 GTO - limited slip diff oil? nikolas 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-05-2008 02:51 PM
What type of limited slip is in the GTO? Whiteshadow Service, Maintenance and Technical Discussion 7 04-13-2005 08:51 PM
