M21 trans question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 10-12-2017, 09:41 PM Thread Starter
Quoted: 17 Post(s)
M21 trans question
On a 69 that came with the M21 4 speed, should the speedometer cable exit the driver side or passenger side of the transmission?? Thanks
greenjudge69 is offline
post #2 of 3 (permalink) Old 10-12-2017, 10:49 PM
Dug through some old 45mm pics, from a 34K mile Pontiac plant built '69 RAIV Judge that went to OH for in '93, speedo cable was drivers side. trans was orig vin stamped. I have ran across coming out te pass side, need to contact friend who has all numbers match Arlington RAIII Judge.
factory installed M20 (& 3.23 or 3.55 gears), will def have drivers side tail shaft speedo outlet, have rebuilt two '69 M20's.
post #3 of 3 (permalink) Old 10-13-2017, 04:17 PM Thread Starter
Quoted: 17 Post(s)
Thank you. I may have found an m21 for my judge. Just wanted to make sure about the correct location.
70 judge Trans M20 or M21? 1970gto455conv 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 3 08-16-2014 12:25 PM
Trans vacuum question frudedude2 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 11-18-2011 01:35 PM
Saginaw to m21 question Cpldavis37 1964-1974 Tempest, Lemans & GTO General Discussion 10 03-30-2011 11:09 PM
79' trans am shaker question thansgto The Lounge 1 12-22-2007 03:55 PM
Trans cooler question 04 Goatman Service, Maintenance and Technical Discussion 0 09-22-2007 04:21 PM
