Maiden start!! Fuel pump question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 01-21-2012, 04:12 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
Hoping to do the maiden start tonight or early in the AM. Any advice would be helpful. Already primed oil pump and set timing to #1 at TDC, I am going to hook up the fuel pump to a gas can since I havent dropped the tank yet.
My question is which side of the fuel pump is the inlet ? I know its one of the two nipples... just curious
FlambeauHO is offline
post #2 of 3 (permalink) Old 01-21-2012, 04:30 PM
Quoted: 98 Post(s)
The inlet is the bent pickup tube on the left. The 1/4" straight line is your vapor return line to tank (plug it if your car is without this option), and the hex fitting is where your steel fuel line to the carb goes. Good luck, and keep a fire extinguisher handy. I've been doing this forever, and I always seem to get the darn distributor in 180 out!!!
post #3 of 3 (permalink) Old 01-21-2012, 09:49 PM Thread Starter
FlambeauHO's Avatar
Quoted: 8 Post(s)
Thanks, got it hooked up!
Different Fuel Pump Question Pontiacdude 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 05-13-2011 04:59 PM
fuel pump question... Instg8ter 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 5 05-12-2011 03:32 PM
Fuel pump help needed, Will not start Richtenb Interior Discussions 2 03-12-2011 02:51 AM
Fuel Pump Question Jim 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 6 05-12-2010 09:19 PM
06 fuel pump question 06GOAT Engine Discussions 2 05-09-2008 06:32 AM
