To media blast or not. - Pontiac GTO Forum
post #1 of 31 (permalink) Old 10-27-2010, 05:57 PM Thread Starter
OrbitOrange's Avatar
Had a guy come by and give me an estimate on media blasting my car and frame. $1400
Thats more than I can afford. So Im thinking I will sand it all down to the bare metal. Patch any rust areas that can be cut out and welded. Any that cant treat and cover with POR 15.
But my friend who knows a little bit about body work (more than I know) says that if I do not media blast it then in a few years I will be seeing rust bubbles and such again.
Any advice is greatly appreciated. Trying to deceide which direction to go with this right now.
OrbitOrange is offline
post #2 of 31 (permalink) Old 10-27-2010, 07:29 PM
Ya can't beat a good media blasting! If you don't have experiance sanding, you will gouge surfaces and ruin body lines......if you can't afford the blast, wait till you can. My $.02 Eric
Eric Animal is offline
post #3 of 31 (permalink) Old 10-27-2010, 08:12 PM Thread Starter
I always appreciate your advice Eric.
I think I am gonna go ahead and have it done in about a month from now. Take me that long to get the rotisserie done and the car unassembled. The more I think about it the more I about how Im gonna always have that in the back of my head that I didnt do it.
post #4 of 31 (permalink) Old 10-27-2010, 09:28 PM
Thor7352's Avatar
Hey,
I've used media blasting for my project because on previous bodywork experiences media blasting is the only way to fully kill rust.
On my current project, (link below) I've decided to use a 'selective' media blasting method. The car has a lot of long, flat and un-dented panels that media blasting would warp. So instead I use orange paint and paint all of the areas that I want media blasted. Then the guy that does my blasting only hits those areas. This will allow me to use a DA sander to strip the large flat surfaces and avoid warpage and still kill the rust.
Check out the trunk lid on page 3, it was pretty successful;
My Restoration Project
Are other ways wrong...nope, this is just my way.
Thor7352 is offline
post #5 of 31 (permalink) Old 10-27-2010, 10:43 PM
jetstang's Avatar
Media blasting is the prefered method, but if funds don't allow it sanding is fine and cheaper. I didn't strip my 70 to metal, and I'm doing my 66 now, and not stripping it either. It's nice to take it down to nothing and redo it all, but if the old bodywork isn't popping or doing anything ignorant, you can just leave it alone.
Remember, it's better to do it once and do it right, but cheaper to hope the old body work holds and maybe do it again later when you have more money and actually finish the project now and not let the body work hold you up from ever finishing.
It took my buddy 22 years to finish his 63 Chevy II because he couldn't do the body work and paint the firewall, and my other buddy spent 10 years doing a 55 Chevy. Both cars are sweet now, but they have over $30K in each of them.
Burning rubber since 1982!!
jetstang is offline
post #6 of 31 (permalink) Old 10-28-2010, 08:05 AM
daveh70's Avatar
You should also think of the money you'll be putting into the car and what it's value is. Does it make sense to put in tremendous money that you may never see again, assuming it's not your "forever" car?
daveh70 is offline
post #7 of 31 (permalink) Old 10-28-2010, 08:18 AM
i would say no. it is just a lemans. if you are already concerned about money in the cleanup stage you may have problems finishing it if you blast it. blasting exposes all kinds of bodywork sins that are expensive to fix. if you just want a nice driver patch the rust spots paint it and enjoy.
freethinker is offline
post #8 of 31 (permalink) Old 10-28-2010, 09:19 AM
Quoted: 118 Post(s)
Jetstang brings up an interesting and very valid point: finishes that haven't failed in 20 -45 years are not likely to. Factory primer is the best there is...it's baked on, and if still doing it's job, I like to leave it alone. It's the "good stuff" with all the lead and toxins you need for a durable finish! I had a GTO stripped to bare, saw it in the raw, and it wasn't raw long. Everything was done right, and the car came out mint. Thing was, about 10 years later, some rust bubbles began to show in the paint. This was a rust free car....we're talking bubles on the tops of the fenders, hood, etc. My '65 was repainted 25 years ago over the factory finish and no rust. My '67 was painted 17 years ago over several finishes, but the car's never been stripped...just block sanded. Unless the car is in a super dry environment and treated immediately, it will flash rust. It may look perfect when done, but if you keep it for a long time, bad things can emerge. I am a BIG FAN of not stripping down to bare metal IF the car does not have rust issues and the old finish is solid. Being in California, this may very well not be a viable option for a lot of you folks.
post #9 of 31 (permalink) Old 10-28-2010, 09:32 AM
i agree.
post #10 of 31 (permalink) Old 10-28-2010, 09:39 AM
66tempestGT's Avatar
X2^^^
Shane Doss
66 tempest
64 el camino
02 mullis dragster
66tempestGT is offline
Educate me on media blasting [email protected] 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 3 05-05-2009 09:53 AM
Jet Blast TexasRealtor The Lounge 1 11-08-2006 11:37 PM
A Blast to Drive! SpaceCoast 2004-2006 GTO General Discussion 5 06-20-2006 08:48 PM
Stock stereo and CD media Clueless 2004-2006 GTO General Discussion 13 03-14-2006 07:16 PM
Who here hates the media? ForsakenNoob The Lounge 32 02-02-2006 11:37 PM
