Muncie 4 speed question - Pontiac GTO Forum
post #1 of 3 (permalink) Old 09-07-2018, 04:52 PM Thread Starter
Quoted: 17 Post(s)
On a 69 judge with an M 21 trans,. What are the correct casting numbers for the main housing,. Tailshaft housing,. And side cover? Also, should it have the bolt on,. Or stud and nut style of mounting for the linkage levers? I believe the speedometer hookup should be on the driver side of the tailshaft housing. Thank you.
greenjudge69 is offline
post #2 of 3 (permalink) Old 09-09-2018, 04:15 PM
integrity6987's Avatar
Quoted: 50 Post(s)
recommend you buy GTOAA id guide by Eric White. From that book can get some answers:
M-21 from 1969 should have FT ide code and be mated with 3.90:1 or 4.33:1 diff.
DK
integrity6987 is offline
post #3 of 3 (permalink) Old 09-09-2018, 06:55 PM Thread Starter
Quoted: 17 Post(s)
Thanks for your assistance. My car has it's original rear with the 3.90 gears still in there.
Muncie 4 speed question wishihaditback 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 9 02-11-2015 06:23 PM
66 gto muncie 4 speed vibration / rattle in shifter "at speed" take5 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 11 10-28-2010 08:43 PM
Muncie 4 Speed Phs Documentation Question take5 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 21 07-08-2010 01:36 PM
71 GTO Coversion To 4-Speed Muncie 69classic 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 05-27-2009 05:35 PM
