Muncie Trans & Hurst Shifter Match - Pontiac GTO Forum
post #1 of 2 (permalink) Old 05-01-2019, 10:04 AM Thread Starter
My 65 GTO is being restored and there is now an issue with the transmission and shifter. Per PHS the car came with a 3 speed trans. When I bought the car in 1978 it had a four speed with console but a non Hurst shifter. From the markings it is a 70-74 trans. I have purchased the correct Hurst shifter for a 65 with console, but can't locate a mounting bracket that will attach to the tail shaft and to the shifter. Trans numbers are: Main case 3925661, tail shaft 3978764, front nose T89C-6A, side cover 335608. Front shaft splines 26, rear 32. The trans has been rebuilt and I had a new drive shaft built. Would appreciate any guidance on how to match the trans and shifter - or do I need to get a different shifter or a different transmission.
Thanks,
sidthecpa is offline
post #2 of 2 (permalink) Old 05-01-2019, 05:26 PM
Quoted: 333 Post(s)
Looks like these guys might be able to answer your question or help. They offer a mounting plate for the Super Shifter. Otherwise, you may have to check Ebay to get a used one. https://www.hurstshiftersonline.com/...categories.asp
Hurst 4 speed in 70 GTO...Muncie in 68 and 69? jayvee53 1964-1974 Tempest, Lemans & GTO Undercarriage, Frame, Transmission and Differential Discussions. 1 09-15-2018 08:28 AM
Short throw shifter like a Hurst Super Shifter for a '69 Goat with console? Stan's Customs 1964-1974 Tempest, Lemans & GTO General Discussion 3 05-02-2018 12:18 PM
TH400 shifter - console Hurst or B&M swap-out ques manfromnantucket 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 3 05-11-2014 10:54 AM
