My 67 GTO Frame Off Rest - Pontiac GTO Forum
post #1 of 9 (permalink) Old 12-20-2015, 02:15 AM Thread Starter
Hello,
I'm currently restoring my 67 GTO. Just to get you all up to speed on what I have going on. Because I started this resto about 6 months ago and im just now getting on this forum.
I bought a 67 GTO from a buddy of mine that buys and sells old cars. Needed some work but I am really mechanical incline. Although this is my first restoration I have done a lot of work with different cars.
The first couple of pictures are when I actually picked up the car and took it home. And the next couple of pictures are when I took the body off and began the restoration.
To begin with I totally disassemble everything and began sand blasting on the frame. Which took forever.
Then I went ahead and painted the frame with a black rattle can frame paint.
After that I began to replace parts that needed to be replaced. I kept the control arms except the lowers I got some new originals and I shoved all new polyurethane bushing and ball joints in all everywhere that had bushings and dumbed the rubber bushings.
After that I began with the assembly of the front end. Ordered new springs (Factory Height). After market Shocks and Sway bar. Also, I upgraded the front drum brake to a disc brake kit (GetDiscBrakes). Which allowed me to keep the stock spindles. I ran with this because I didn't want to drop the car before I placed the motor in with the headers and the long tube headers might be to low to the ground. So for now I am just bring it back to stock height.
Also, because of the motor which I am about to get to. I decided to go ahead and go with the 12 bolt instead of the 10 bolt rear end. Which I picked up from a buddy of mine that is off a 70 A-Body frame. Also, is a half inch longer on both sides but getting a 67 rear end with 12 bolts is nearly impossible unless I spend a lot of money. So I picked up a 12 bolt that needed some sandblasting for a 100 bucks.
On to the motor and the part that will piss some people off. I currently have the numbers matching motor for the car and all the numbers matching stuff set to the side. But I am wanting to build big power and have fun and besides I am very good with Chevy motors so I've decided to store that Pontiac motor and have some fun with the Chevy 496 Stroker motor followed by a Jakes Performance Transmission 4L80. Just know that if I ever decide to sell it which I am a 100 percent sure I wont I will be able to place all the numbers matching stuff back in it. So that's why I ran with the 12 bolt to support the low end that the Chevy cranks out.
My overall goal with this car is to turn it all back to original excluding the motor and the rest of the drive train. Everything will be original inside and out. I hope that you all enjoy some of the pictures that I post and feel free to drop a comment or advice except the negatives about a Chevy in a Pontiac.
ID:	68778   Click image for larger version
ID:	68786   Click image for larger version
ID:	68794   Click image for larger version
ID:	68802   Click image for larger version
67PONGOAT is offline
post #2 of 9 (permalink) Old 12-20-2015, 02:18 AM Thread Starter
More Pics
ID:	68818   Click image for larger version
ID:	68826   Click image for larger version
ID:	68834   Click image for larger version
ID:	68842   Click image for larger version
post #3 of 9 (permalink) Old 12-20-2015, 02:20 AM Thread Starter
A few more pics
ID:	68874   Click image for larger version
post #4 of 9 (permalink) Old 12-20-2015, 02:54 AM Thread Starter
Here you go
ID:	68898   Click image for larger version
ID:	68906   Click image for larger version
ID:	68914   Click image for larger version
ID:	68922   Click image for larger version
post #5 of 9 (permalink) Old 12-20-2015, 03:01 AM Thread Starter
Pictures of the body
ID:	68938   Click image for larger version
ID:	68946   Click image for larger version
ID:	68954   Click image for larger version
ID:	68962   Click image for larger version
post #6 of 9 (permalink) Old 12-20-2015, 03:05 AM Thread Starter
This should be it.
ID:	68978   Click image for larger version
ID:	68986   Click image for larger version
ID:	68994   Click image for larger version
post #7 of 9 (permalink) Old 12-20-2015, 10:48 AM
Welcome to the forum, I've pinned your thread to the top of the forum because I and many others on this forum would like to follow your progress.
I completed a frame off nut and bolt restoration a few years ago and documented the process in my photo gallery. My car was in the same condition as your car.
Here is a link to my photo gallery starting on page 25 and you may find some answers to some of your questions on panel replacements.
Good luck and keep the pictures coming.
05GTO is offline
post #8 of 9 (permalink) Old 12-26-2015, 09:38 AM Thread Starter
Question
Man that thing is a beauty thanks and will for sure use some of your pics for a reference. Hey I got a quick question do you think that a 3/8 fuel line will sit in the factory clips that are on the frame?
post #9 of 9 (permalink) Old 01-10-2016, 12:34 PM
I liked the pine cone in the dash photo will be a cool car when you get done with it
LARRY HANSON is offline
Foot rest johnfin Interior Discussions 0 01-06-2015 03:01 PM
Could you order a 68 GTO bucket seat with head rest par4n1 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 1 01-22-2012 12:13 AM
Arm rest ? MickeyKelley 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 6 11-30-2011 07:27 PM
Rest Alert GoatPwr 2004-2006 GTO General Discussion 7 08-26-2008 12:25 PM
05 gto put to rest bluebeast Racing and Kill Forum 34 06-26-2006 03:24 AM
