My new restoration project - Page 3 - Pontiac GTO Forum
 2Likes
post #21 of 23 (permalink) Old 05-18-2019, 10:02 PM Thread Starter
Reddirtroad's Avatar
Quoted: 5 Post(s)
Justvdetailed the rear axle.
The rear was all rebuilt and is from a 1968 GTO 4 pinion Posi with 3:55 gear ratio,
I sandblasted the axle. Drained and refilled with new gear oil and additive.
Replaced the dented rear cover with new, new brake lines, Brakes and inspection marks and decals
ID:	119071   Click image for larger version
ID:	119073   Click image for larger version
ID:	119075   Click image for larger version
clevelandpartsguy likes this.
Reddirtroad is offline
post #22 of 23 (permalink) Old 05-19-2019, 12:06 PM
Quoted: 333 Post(s)
Looks great, well done with all the detail into it. If your car does not already have these, while you have the rear end out and can get to everything, I would add either the factory style reproduction upper/lower control arm braces https://www.opgi.com/gto/D250054/ or spring for a set of aftermarket braces. 1964-1967 GM A-Body Control Arm Reinforcements/Frame Braces [4029] - $129.99 : UMI Performance, Inc. The 4 speed cars had them, but it does help to add some strength to the frame mounting points if you plan on "using" the car.
https://www.gtoforum.com/f122/rear-r...braces-105514/
post #23 of 23 (permalink) Old 05-30-2019, 11:55 AM Thread Starter
Quoted: 5 Post(s)
A little more progress
Sandblasted the wheels over the past weekend
Applied self etch, Painted back of wheels in gray enamel, taped and sprayed with Argent silver then charcoal.
New caps and lugs
You Rally I guys have it easy..haha
A lot more taping and masking on a Rally II
ID:	119305   Click image for larger version
ID:	119307   Click image for larger version
ID:	119309   Click image for larger version
ID:	119311   Click image for larger version
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
Montreux
A new guy with another '68 GTO restoration project GasTiresOil 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 9 11-13-2009 10:48 AM
A new restoration project for a '68 GTO convertible, what is the best parts source? GasTiresOil 1964-1974 Tempest, Lemans & GTO Convertible Top, Interior, Glass and Trunk 4 11-08-2009 10:49 AM
starting restoration project, need info DrBoeing 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 13 09-28-2009 04:01 AM
Project: 1967 GTO Mechanical Restoration opelspyder 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 17 08-27-2007 11:26 AM
