Need advice on Vacuum connections - Pontiac GTO Forum
post #1 of 8 (permalink) Old 11-25-2011, 08:29 PM Thread Starter
Ramairbird's Avatar
I just bought a new intake and rebuilt carb to replace the old 2bbl that came with my 1972 GTO. The motor is a 1971 400 and was rated for 265 hp. The old carb was gunked up and needed rebuilding so I opted to go ahead and get a 4bbl and new intake. The question I have is around the vacuum connections. On the old 2bbl intake there are no vacuum connections into the intake - on the new one there are two. Can someone tell me which of these two are for the connection to the PCV valve and what the other one is for?
ID:	13087   Click image for larger version
Ramairbird
Ramairbird is offline
post #2 of 8 (permalink) Old 11-25-2011, 09:16 PM
Most often I've seen the PCV valve connected to the one on the "left" in your photo - the one closest to the passenger side. The other one, you can use for "whatever" --- transmission vacuum modulator, for example, or power brakes. If you don't need it, just cap it with a good quality rubber (not vinyl) cap.
post #3 of 8 (permalink) Old 11-25-2011, 10:01 PM
Most after market suppliers will have this adapter,
05GTO is offline
post #4 of 8 (permalink) Old 11-25-2011, 10:26 PM Thread Starter
Ramairbird's Avatar
Thank you Bear and 05GTO. I certainly appreciate the advice.
Ramairbird
post #5 of 8 (permalink) Old 11-26-2011, 07:26 AM
jigaway's Avatar
When you get er going, run it down here to the Shenandoah valley..
Best of luck with the resto
Dan
jigaway is offline
post #6 of 8 (permalink) Old 11-26-2011, 10:52 AM
Quoted: 102 Post(s)
As 05's photo shows, BOTH outlets are for PCV. There is a Tee that is needed to connect the hoses, and also, one of the hoses is "formed". All available at the vendors.
post #7 of 8 (permalink) Old 11-26-2011, 11:32 AM
The TEE, I believe was only used in 66 and 67, your set-up with the Carter AFB appears to be from a 66.
05GTO is offline
post #8 of 8 (permalink) Old 11-30-2011, 07:33 PM
that is a 66 intake with an AFB, thus the dual ports for PCV.
pontiac is offline
carb connections Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 03-05-2011 11:52 PM
starter selenoid connections Topkat 1964-1974 Tempest, Lemans & GTO General Discussion 3 02-26-2011 04:43 PM
PCV connections Topkat 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 02-23-2011 06:28 AM
Confused About Fuel Pump Connections peahrens 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 12-03-2010 12:25 PM
Battery Tender...Connections... silversport Service, Maintenance and Technical Discussion 8 02-11-2009 10:06 PM
