Need help - Pontiac GTO Forum
post #1 of 3 (permalink) Old 12-09-2018, 10:30 AM Thread Starter
Need help
Lost my disassemble pics and trying to figure out where these go in my reinstall of my front and rear qtr windows on my 68 convertible. Any one?
Mike Buttrey is offline
post #2 of 3 (permalink) Old 12-11-2018, 10:19 AM
1968gto421's Avatar
Quoted: 70 Post(s)
Try looking at Shake-N-Bake's thread on restoring his '68 convertible. If you don't see it there, you could PM him for assistance. He's a good guy.
https://www.gtoforum.com/f83/restori...doo-ii-127321/
Best of luck with your restoration.
1968gto421 is offline
post #3 of 3 (permalink) Old 12-11-2018, 05:39 PM
Quoted: 78 Post(s)
The item at the lower left of your photo is for the door glass sash channel. It's a stop that is bolted to the forward edge of the sash near the vertical glass run channel that makes up the vent window assembly. It's circled in the attached diagram but not numbered.
The other two items are for the quarter glass assembly. Item numbers 1 and 4 in the diagram. You aren't showing item 6 in your photo, perhaps you have that one figured out already.
I noticed that you have two fasteners in the upper rear stop for the quarter glass....that piece only receives one bolt. It has two threaded holes because that same part is used on either side of the car. One hole is used, the other is abandoned depending on what side of the car it is on.
Hope this helps.
Name:	door glass assembly.jpg
ID:	116723   Click image for larger version
Name:	Qtr Glass assembly.jpg
ID:	116725   Click image for larger version
Name:	door glass rail 2.jpg
ID:	116727   Click image for larger version
Name:	door glass rail.jpg
ID:	116729   Click image for larger version
Name:	qtr glass stops.jpg
Shake-N-Bake is offline
Need help figuring what piston I need. (wallace calculator) RMTZ67 1964-1974 Tempest, LeMans & GTO Engine Tuning and High Performance 16 07-19-2018 12:24 PM
Need help, Received Maggie 112.need coolant resevoir? cpr Engine Discussions 14 04-10-2010 10:11 AM
Need help. I need a/c vent temperatures. justin-branam 2004-2006 GTO General Discussion 3 06-20-2009 10:16 AM
Dallas Area help.....need help on a clear bra shop TexasAggie Exterior Discussions 3 07-08-2006 02:09 AM
