Need help removing ignition switch/bezel. - Pontiac GTO Forum
post #1 of 7 (permalink) Old 03-24-2015, 10:10 AM Thread Starter
Can anyone tell me how to spin off the bezel on a 66 lemans dash?I have tried to stick a small wire and spin it with no luck,maybe i don't have the key in the right position?
alanderson is offline
post #2 of 7 (permalink) Old 03-24-2015, 01:25 PM
It takes a special socket, but I've had luck with a snap ring pliers when I changed mine. I would tape up the dash around the tumbler to avoid any damage if the pliers slips off.
post #3 of 7 (permalink) Old 03-24-2015, 07:07 PM
same problem
I have a slightly different problem with my 68 even with the dash out. I can spin the bezel loose so that the ignition switch and bezel are flopping but the bezel is hung up and will not separate so that I can pull out the switch.
frankrp is offline
post #4 of 7 (permalink) Old 03-24-2015, 10:06 PM
I did it about two years ago. On the front of the lock cyl there is a small hole next to the key hole.
Put the key in the lock cyl and turn it to acc and then take a paper clip and straighten it out and put it in the small hole next to the key.
Then push paper clip in hole as far as you can and then continue to turn the key to the acc (to the left) until the lock cyl pops out.
Then if you want the switch out of the dash the trim ring should twist off it and pull out from behind
tonyli is offline
post #5 of 7 (permalink) Old 04-02-2015, 07:43 PM
ignition switch bezel
Thanks for the input haven't tried it yet but will check it this weekend thanks again
frankrp is offline
post #6 of 7 (permalink) Old 04-08-2015, 10:29 AM Thread Starter
Worked perfect,the problem with it was the insert/key was gummed up and wouldn't slide out even though it was loose,but a good soaking of break free got it.Thanks for the input.
post #7 of 7 (permalink) Old 04-04-2017, 08:30 AM
alanmay0's Avatar
I have the same problem but my 1967 GTO has no accessory position. Just on and then the spring loaded start position. So far nothing has worked. Any other suggestions???
thanks
alan
alanmay0 is offline
68 Ignition Switch kilkm68 1964-1974 Tempest, Lemans & GTO General Discussion 1 06-28-2014 08:57 AM
67 Ignition switch lam63 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 06-13-2012 02:44 AM
new ignition switch BillGTO 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 10-26-2009 02:34 PM
65 ignition switch asshauler 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 4 02-25-2009 11:58 PM
Ignition Switch? 66_goat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 7 10-29-2007 10:13 PM
