OK shifter and linkage...What am I doing wrong? - Pontiac GTO Forum
post #1 of 5 (permalink) Old 10-14-2011, 07:27 PM Thread Starter
xconcepts's Avatar
So I got the hurst linkage from TPP and appear to have it bolted to the tranny correctly, but I cannot for the life of me get it to shift into any gear. What am I doing wrong or what do I need to do to fix this? Do I need to do one by one and adjust every gear? As far as shifting it into 1st adjusting the linkage to first and checking second, then 3rd, 4th and rev?
X
xconcepts is offline
post #2 of 5 (permalink) Old 10-15-2011, 07:57 PM Thread Starter
xconcepts's Avatar
Anyone?
post #3 of 5 (permalink) Old 10-16-2011, 08:25 AM
You might have hooked the linkage up correctly, BUT with one of the shift levers in the wrong position. Loosen the linkage rods, put the shifter in neutral, install the "alignment rod" into the shifter. Then place all the shifter (3) levers on the tranny in neutral, and tighten. SOMETIMES, the trans gets hung in 2 gears at once ...and nothing will move. Hard to explain with out being there........ Eric
P.S. Make sure the shift alignment rod is not presently in the shifter .....as this will stop the shifter from moving.
Eric Animal is offline
post #4 of 5 (permalink) Old 10-16-2011, 05:17 PM Thread Starter
xconcepts's Avatar
So I was finally able to get the shifter to move. I got all the drive gears working but I still can't get reverse in gear. I thought maybe my shifter was bad but even using my short shift it won't go in reverse.
post #5 of 5 (permalink) Old 10-16-2011, 10:43 PM Thread Starter
xconcepts's Avatar
Finally got the linkage and gears to all work. I couldn't get the OEM adapter plate I bought 2 weeks ago to work with it thou and had to use the Hurst plate that came with the linkage kit. Hopefully Ames will let me return it. Now on to the console
Question about 64 GTO powerglide shifter linkage Bryan H 1964-1974 Tempest, Lemans & GTO General Discussion 3 05-09-2013 10:24 AM
Identify Shifter linkage xconcepts 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 0 10-11-2011 06:46 PM
66 Shifter linkage xconcepts 1964-1974 Tempest, LeMans & GTO Projects, Barn Finds & Restoration Discussions 2 04-24-2011 01:47 PM
carb linkage Topkat 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 1 02-19-2011 06:09 PM
