one piece trunk installation - Pontiac GTO Forum
post #1 of 12 (permalink) Old 01-08-2012, 10:39 AM Thread Starter
Hi all, I am about to move to the trunk area of the 66 conv.
Question. I bought a 1 piece floor with braces some time ago and am finally getting around to put it in. Can anyone offer some advice and possible pictures of their experience doing this?
Must I go from the bottom up or can I go thru the convertible top area to get the 1 piece trunk in place.
Thanks,
Hank
Spanky64 is offline
post #2 of 12 (permalink) Old 01-09-2012, 10:48 AM
Quoted: 99 Post(s)
Lots on this subject here and on the py forum. The body has to come off the frame to install a one piece floor. It goes in from the bottom.
post #3 of 12 (permalink) Old 01-09-2012, 05:42 PM
The body doesn't have to come all the way off though. Someone has a thread either here or on the py forum about getting the rear of the body loose by removing the rear mounts and loosening the others and lifted up just enough to slide in a full pan from the rear. Probably would want the front sheet metal off before doing this.
Russ
russosborne is offline
post #4 of 12 (permalink) Old 01-10-2012, 10:33 AM Thread Starter
I have a new frame that is ready to go and the old frame is still on the car with everything forward of the firewall cut off. Body bolts are out so the car is just resting on the old frame. Should I put the body on the new frame first? or as Russ sugested just jack it up cut it out weld it in then place on new frame.
I do not want to screw this up guys so any and all help is appreciated.
Hank.
Spanky64 is offline
post #5 of 12 (permalink) Old 01-10-2012, 02:59 PM
Quoted: 99 Post(s)
Put the new trunk floor in before putting the body on the new frame. Be super careful that you don't crush your hands, etc. If the old frame is junk anyway, you can use it as a fabrication horse and do as russ said, etc.
post #6 of 12 (permalink) Old 01-10-2012, 03:47 PM
Yeah, that does make life a lot simpler. :-)
As long as what's left of the original isn't bent or out of shape, use that to make sure the new floor is aligned and stayed aligned after you weld it in and then put the body on the new chassis.
Russ
post #7 of 12 (permalink) Old 01-10-2012, 04:01 PM Thread Starter
Should I remove the tail panel first? I see some have suggested so.
Spanky64 is offline
post #8 of 12 (permalink) Old 01-10-2012, 04:30 PM
If it doesn't need replacing, I'd say no.
post #9 of 12 (permalink) Old 01-10-2012, 04:49 PM Thread Starter
It does need replacing, so which way should I go?
Seems like a dumb question but from a point of alignment?
Thanks!
Spanky64 is offline
post #10 of 12 (permalink) Old 01-11-2012, 04:08 PM
Is either of them really in worse shape than the other, or are they both pretty much the same (as far as straightness, rust, etc)? If there is a big difference, leave the better one on and replace the worst one first. If the same, flip a coin?
I can see pros and cons to doing it both ways. Like that really helps you much.
Russ
and yet another 65 carbon piece crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 17 03-09-2009 09:56 PM
another 65 carbon piece crustysack 1964-1974 Tempest, LeMans & GTO Technical and Electrical Wiring 8 02-08-2009 11:47 AM
Is the gto a piece of crap? JMVorbeck Service, Maintenance and Technical Discussion 42 02-25-2008 07:24 AM
I now have my very own little piece of NASCAR :D lisatw151 Audio & Video Clips 4 04-27-2006 04:23 PM
